Thread: I Need Help! Major Car Problems :( I Feel Like Crying...
Results 21 to 40 of 47
  1. #21 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    A little seeping leak is nothing as long as you've kept the oil level up where it should be.
    Now.. you say you were out with your friend. This "happened" when you stopped for a light and while that is possible, it's my experience it's not always the case.
    Lemme ask you this question then.. how fast were you going say in the 20 minutes before this..and or .. did you win the race?
  2. #22 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    PS, Since Ryno is helping Hippo...I'm kinda wondering where the other guys like Elephant and Giraffe are?
  3. #23 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Topeka, KS
    I didn't help i just pointed out the obvious.
  4. #24 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Quote Originally Posted by rynoman03 View Post
    And that's helpin when a guy doesn't know the obvious. I tell guys what I think is the obvious all the time. And they thank me for helping them.
  5. #25 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Hey thats a downer man but litsen to some of the guys on here and thet will help get you fixed up
  6. #26 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Jun 2011
    Detroit, MI
    if you knew of the issue that is causing your problems it is your fault for not fixing it.
    we didn't know it was causing a problem! The mechanic never told us it was.
    iLoveSpade
  7. #27 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Jun 2011
    Detroit, MI
    Yes about EXACTLY 20 minutes b4, i floored it on the freeway to see if the car was any fast. It got up to 80 MPH and didn't accelerate anymore, which is probably when it "happened".
    iLoveSpade
  8. #28 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Sucks that you only got to 80mph. Likely though..if it stopped accelerating, that's when the knock sensors detected an issue (noise) and pulled timing which you later could hear.
  9. #29 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    St. Louis
    What else is sqeaking/tapping in that vid? It almost sounds like the waterpump is bouncing around. Although it does sound like a rod knock, have you tried removing the belt and starting it for a short time to see if the noise stops? Obviously don't let it run for more than a minute or 2 w/o the belt.
    I've done work on other cars where accessories go bad and have a knocking noise (waterpump once, tensioner pulley x2). I just wonder that if at 80mph (which would be about 2500+ rpms in a GT) something is wobbeling enough to be picked up by the knock sensors?
    Just trying to look at this from another angle (hopefully a less costly one)
  10. #30 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Jun 2011
    Detroit, MI
    Quote Originally Posted by FordMan77 View Post
    Actually it was getting up to 5000 RPMs (no idea what gear) at 80 mph, so took my foot off the gas, idk.
    iLoveSpade
  11. #31 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    5K...would have been about 80mph...in 2nd.
    So yeah...poof.
  12. #32 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    One thing is for sure. Something is efffed. Does not sound good
    2003 Grand Prix GT
  13. #33 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Troy OH
    drain oil and look for streaks man. that'll tell you almost for sure if you have rod or crank damage.
  14. #34 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Quote Originally Posted by Hippo Machine View Post
    Ok, when I went to the mechanic, he just said the oil pan was the main problem. He said it was leaking, but we only saw a drip or so of oil every two days, so we didn't have it fixed yet. On the other hand he said we didn't need to get the other leaks fixed right away. SO it doesn't really sound like my fault, so quit making me feel like it is.
    Of COURSE it's not your fault, you admitted in your post that your mechanic told you about all the gaskets that were bad. Gaskets aren't made to leak..........shocking, I know, but true. If one is leaking, it is a PROBLEM and needs to be fixed IMMEDIATELY.
    But of course it's not your fault..
    LMFAO at the rest of this post though............now the kid says he was going WOT to see if it was "any fast" with a broken oil pan gaskets, LIM gasket, and valve covers.
    You fail at cars, buy a hundah
    For all your 3800 needs:
  15. #35 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    Just junk it and get a VW.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  16. #36 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Jun 2011
    Detroit, MI
    Quote Originally Posted by copgtp View Post
    Go drive off a cliff, jerk.
    iLoveSpade
  17. #37 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    new motor or new push rods and whatever else needs to go with it! either way its gonna cost a little more to repair than replace the engine
  18. #38 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Troy OH
    Quote Originally Posted by RyanL View Post
    new motor or new connecting rods and whatever else needs to go with it! either way its gonna cost a little more to repair than replace the engine
    fixed. connecting rods and crankshaft. but the rest it true, it'll be cheaper to buy and swap in a replacement motor
  19. #39 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Topeka, KS
    Ok i'll give you the benefit of he doubt right there.
    It does suck your motor is trash but you can get a drop in motor for a decent price these days other than being out X amount of money to get it done.
  20. #40 Re: I Need Help! Major Car Problems :( I Feel Like Crying...
    Jun 2011
    Detroit, MI
    Perfect avatar for this thread haha.
    iLoveSpade
  1. How do you feel...
    By HighOctaneRacing in forum Off Topic Discussion
    Last Post: 03-20-2011, 10:52 AM
  2. Major dealership problems!!!
    By whiney in forum Off Topic Discussion
    Last Post: 12-18-2009, 11:09 PM
  3. Major Electrical Problems
    By Lighty in forum General Tech Discussion
    Last Post: 12-13-2009, 01:46 AM
  4. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
  5. Major Problems Please Help
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-11-2008, 08:52 PM
