Thread: Leaking problem! Help please
Results 1 to 4 of 4
  1. #1 Leaking problem! Help please
    GTX Level Member nikkigpgt00's Avatar
    MI
    My left corner lense keeps filling with water! What can I do? It's only a few months old and has been doing it almost since I got them. I check for holes and cracks and found nothing. Please give me some ideas!
  2. #2 Re: Leaking problem! Help please
    take a small drill bit and drill a hole in the bottom, drill it close the the plastice lense so its not see-able. then take a vacuum or shop vac and suck out the water and to help air dry the inside, do that for a few minutes then let them sit in the sun for a while.
    I just did that and have not had a issue since, I can snag a pic of where I drilled the hole if ya need one.
  3. #3 Re: Leaking problem! Help please
    Grand Island, Nebraska
    Or you can buy some clear corners off ebay.
    EDIT: Nvm just saw you have them already.
  4. #4 Re: Leaking problem! Help please
    Dec 2008
    Lawndale, CA
    Usually a bead of silicone around the bulb opening helps.
  1. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  2. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  3. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  4. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
  5. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
