My left corner lense keeps filling with water! What can I do? It's only a few months old and has been doing it almost since I got them. I check for holes and cracks and found nothing. Please give me some ideas!
take a small drill bit and drill a hole in the bottom, drill it close the the plastice lense so its not see-able. then take a vacuum or shop vac and suck out the water and to help air dry the inside, do that for a few minutes then let them sit in the sun for a while.
I just did that and have not had a issue since, I can snag a pic of where I drilled the hole if ya need one.
Or you can buy some clear corners off ebay.
EDIT: Nvm just saw you have them already.
Usually a bead of silicone around the bulb opening helps.
