Thread: new to GP forums need help with a heating issue
Results 1 to 8 of 8
  1. #1 new to GP forums need help with a heating issue
    May 2011
    portland
    ok so i have a 1997 grand prix gtp basic no mods just my go to work car recently the temp gauge has been fluctuating going from just under 210 back to the quarter mark had the coolant flushed and bled the bubbles out with the cap off method but still running hotter then normal have the ses light on but i havent gotten a chance to pull the codes yet any help in a next step other then the obvious pulling codes would be helpful and much appreciated thanks
    michael
  2. #2 Re: new to GP forums need help with a heating issue
    Wichita
    Blocked Catalytic Converter? Bad spark plugs?
  3. #3 Re: new to GP forums need help with a heating issue
    May 2011
    portland
    ill look into both thank you
  4. #4 Re: new to GP forums need help with a heating issue
    moved.
  5. #5 Re: new to GP forums need help with a heating issue
    May 2011
    portland
    got the code pulled today came out with p0102 MAP man absolute pressure MAF mass air flow and VAF vane air flow any chance any one has had a similar issue and changed any of these to fix it
    thanks
  6. #6 Re: new to GP forums need help with a heating issue
    Wichita
    Many of us have replaced a MAF sensor and MAP sensor. Cant say i've heard of the vane airflow sensor.
  7. #7 Re: new to GP forums need help with a heating issue
    May 2011
    portland
    so i pulled the clip on the MAF and let it run didnt shoot in temp the fans still continue to turn on but didnt get as hot plugged it back in and it started ideling rougher and just didnt sound good so i would assume this is the issue and replacing is the next step
  8. #8 Re: new to GP forums need help with a heating issue
    Wichita
    Yes if you unplugged the MAF and nothing happened then thats probably your issue. You'll want to get a new MAF.
  1. Heating issue????
    By Zaniac in forum General Tech Discussion
    Last Post: 04-04-2011, 09:01 PM
  2. heating
    By aaddonis in forum General Tech Discussion
    Last Post: 12-27-2010, 06:57 PM
  3. Heating issue
    By DarkJuggalo in forum General Tech Discussion
    Last Post: 12-05-2010, 12:10 PM
  4. Heating issue
    By 98GTPV8etr in forum General Tech Discussion
    Last Post: 11-25-2010, 04:45 PM
  5. GTP over heating
    By Brandon Busenitz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2010, 11:06 PM
