Thread: GTP over heating
Results 1 to 13 of 13
  1. #1 GTP over heating
    Whitewater KS
    My GTP is over heating and I think it's the thermostat. I put a 180 degree fail safe thermostat in it and it locked open and it never got up to operating temperature after that. It got warm enough to read on the gauge but it never got to normal temp, but when it's in, it over heats in a couple miles of driving it. I have a couple of different thermostats that I have tried but it still over heats. Do you have any Ideas?
  2. #2 Re: GTP over heating
    Do your radiator fans kick on?
    Might be a radiator fan fuse
  3. #3 Re: GTP over heating
    Whitewater KS
    Yeah the fans do kick on so I don't think it's that. Any other ideas?
  4. #4 Re: GTP over heating
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    i was long overdue for a coolant flush when i pulled my radiator. how olds the fluid?
    <MiZzBeCcA>its not rape if you yell suprise
  5. #5 Re: GTP over heating
    Definitely consider a coolant flush and changing over to the Green stuff, cause the orange stuff clumps and clogs
  6. #6 Re: GTP over heating
    Whitewater KS
    I just changed it not a month ago and I do have the orange stuff in there(can you mix the orange and the green together?). The thing is when the thermostat is open it cools just fine, it never gets up to regular temperature.
  7. #7 Re: GTP over heating
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Scan it to see what the PCM sees for temp. Your gauge may be off.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  8. #8 Re: GTP over heating
    Quote Originally Posted by torq455 View Post
    This. It could possibly be your Temp Sensor right under the thermo
  9. #9 Re: GTP over heating
    Whitewater KS
    I just did a radiator flush and put in a new thermostat(I didn't use a new gasket for the thermostat), and it still over heats. It runs fine without the thermostat and when it's in I know it's getting hot because it steams, but I haven't hooked up a computer yet to see what it says. Any Ideas?
  10. #10 Re: GTP over heating
    Never Never Land
    Water pump? My car needed one...it would constantly get up to like 230
  11. #11 Re: GTP over heating
    GT Level Member Mitchstrp's Avatar
    Missouri
    dont mix the green stuff and the orange stuff... its like putting gravy in your radiator lol. It gets really thick and will get nasty. coolant flush if thats what happened.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  12. #12 Re: GTP over heating
    centred text necessary?
  13. #13 Re: GTP over heating
    Whitewater KS
    I hooked it up to a computer and it read 122 when the gauge was just above 160 so I think I found the problem. Thanks a lot guys! I still don't know why my thermostat stuck open the first time?
  1. heating A/C question
    By White00GPGT in forum General Tech Discussion
    Last Post: 06-05-2009, 02:26 AM
  2. heating A/C question
    Last Post: 04-29-2009, 08:04 PM
  3. Over heating...
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 06:49 AM
  4. Over heating!!!
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2008, 08:23 PM
  5. Over heating?
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2008, 09:25 PM
