Thread: Air leaking into LIM while doing a Valve job?
Results 1 to 15 of 15
  1. #1 Re: Air leaking into LIM while doing a Valve job?
    Minnesota
    I still have a bunch of other stuff to add before I put it all back together. Mainly an intercooler. I wonder if I could have blown the valve seal when I first added pressure to the cylinder. I will have to recheck it tomorrow because now it has new valve seals and new springs and retainers and locks.
  2. #2 Re: Air leaking into LIM while doing a Valve job?
    SE Level Member FETGYK06GP's Avatar
    north America
    Quote Originally Posted by Pure2sin View Post
    I wonder if I could have blown the valve seal when I first added pressure to the cylinder. .
    When you say valve seal are you referring to the guide seal? More likely to be a burnt valve or seat. Or if your are lucky just carbon build up on the valve keeping it from fully closing. If it was leaking into the intake then its the intake valve and you should be able to see it on a vacuum gauge. How did the spark plug for that cylinder look?
  3. #3 Re: Air leaking into LIM while doing a Valve job?
    This is normal. A valve leaking air from the cylinder into the intake or exhaust is common. When I do springs, I put air to the cylinder and any ones that are leaking a little, I tap with a rubber mallet. Usually helps them seal much better.
    maybe a valve was open, glad it didn't drop in on ya,
    Not with the rockers off. All the springs hold the valves completely shut when the rockers are off. If a valve was open when the cylinder is pressurized with air, the air would run right out. He had a small air leak.
    i bet you got a bad valve seal,
    The valve seal keeps oil from the rocker area getting down the valve guide and into the cylinder. It does nothing to seal the compression chamber.
  4. #4 Re: Air leaking into LIM while doing a Valve job?
    your right bill. it was late and i was sleepy, i was referring to the valve not being seated to the head, the mallet trick works well.
  5. #5 Re: Air leaking into LIM while doing a Valve job?
    Jan 1970
    Maquoketa, Iowa
    Sometimes it takes more than a few taps with the mallet to get them seated properly, I'm surprised you only had trouble with the one. And obviously never do the tapping with the spring off.
  6. #6 Re: Air leaking into LIM while doing a Valve job?
    Good point. With teh rocker off, springs on. That's when I would tap with the mallet.
  1. Leaking hydraulics - proportioning valve
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2011, 01:51 PM
  2. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
  3. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  4. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
