Thread: Transmission problem Update: post rebuild issues
Results 1 to 20 of 26
  1. #1 Re: Transmission problem
    Ask that they check the rear engine cover gasket. It's behind the flex and I've commonly found it to be leaking as well. This would appear to look like an oil pan leak at the drivers end of the motor.
  2. #2 Re: Transmission problem
    Jul 2008
    Nashville, TN
    Thanks for the heads up.
  3. #3 Re: Transmission problem
    Jul 2008
    Nashville, TN
    Ugh.... I've been driving the Monte Carlo for the last month while the Intrigue is a work in progress and think I've got a problem again. To give you some more details, when I got the car back, everything was fine and I drove it from the shop to my house (about 4 miles), then drove it to and from work for a few days before taking it out for a highway drive. During that drive the transmission was acting horribly, so I limped it home only to find that the dipstick was dry. Called the shop, they sent a mechanic over and we quickly figured out that their software called for 3 fewer quarts of fluid less than my factory service manual said it needed. The guy topped off the fluid and everything was fine and well until this week...
    Now when the car is cold, the 1-2 shift is nice and crisp. My Aeroforce tells me that the shift time is around 200 ms. Unfortunately, as the car warms up, the 1-2 shift gets progressively longer and sloppier under the same throttle conditions. By the time I made it to work this morning the Aeroforce was reading upwards of 500 ms for the 1-2 shift.
    The 2-3 shift takes between 400 and 500 ms, which is long enough for me to notice it hanging while accelerating under pretty much any throttle conditions (this has been going on for the last week or two and it's why I started monitoring the shift times). The only shift that is working properly appears to be the 3-4 shift. I haven't noticed any issues with the downshifts like I had been seeing before my rebuild.
    I'm thinking there may have been some damage done when the car was down 3 quarts of trans fluid for the first 50 miles after the rebuild, but I really can't say for sure. All I know is the shift quality has decreased dramatically since the rebuild was done. I'm going to be taking it in sometime in the near future, but wanted to know if anyone thinks this sounds like a PCS problem again. The more I have to tell the mechanic when I show up, the more likely he is to be able to fix it.
  1. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  2. Transmission problem?
    By The LoKi in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-19-2010, 02:43 PM
  3. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
  4. Transmission problem(s)
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 06:34 PM
  5. Odd transmission problem
    By ihartmacz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 12:43 AM
