Thread: ABS and Trac Control off lights
Results 1 to 20 of 27
  1. #1 ABS and Trac Control off lights
    Apr 2011
    Canada
    just bought a 98 gtp and when i step on the gas to spin the wheels it goes and starts spinning then the wheels stop spinning and car accelerates slowly unless release the gas pedal and press it again. is this because the ABS and trac control off lights are on? i thought it was only supposed to that when the trac control is on.
  2. #2 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    bad wheel speed sensor. needs new hub bearing assemblies in the front. abs and trac control wont work otherwise
  3. #3 Re: ABS and Trac Control off lights
    Delaware, OH
    Anytime you break traction with the traction control on it will bog the car down and pull power to help return traction.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    The light is on saying the trac control is off but it still acts like its on
  5. #5 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    your wheels speed sensors in one or both bearings is bad. this will cause the trac control to engage, and the abs to engage when its not supposed to. when mine went bad i nearly wrecked the car trying to fight the abs at 10 mph
  6. #6 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    Awsone thanks for the info, i knew onw of the sensors was bad but i was confused about why it said trac control off but acted like its on. What u said makes sense tho. Once i get around to fixing the sensor ill let you know how it is. Thanks again
  7. #7 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    you cant just fix the sensor. the whole wheel bearing/hub assembly needs replaced on the bad side. take it to a brake shop and they will tell you which one is bad. then go to autozone and buy a new hub assembly. get the Timken, which is more expensive, because the bearing is smoother, the sensor is MUCH BETTER quality, and its made in the USA. the chinese bearings will go bad within the year you purchase them if your not EXTREMELY careful around potholes.
    one last thing, unplug your wheel speed sensors and the car will act normal. you will no longer have abs or trac control and the trac/abs lights will stay on. the brakes and gas pedal will function the old fashioned way, but at least you wont end up rearending some poor bloke because your ABS was keeping you from stopping.
  8. #8 Re: ABS and Trac Control off lights
    if your abs light is on already the abs is NOT WORKING NOW, no need to unplug anything.
    and the brake shop ain't going to scan your abs for free, its a $100 scan at best, unless you got a friend there. or you leave it there for them to fix it.
    jack up your car and see if you have the any play in the wheel by trying to move the wheel from 12 o'clock to 6 o'clock, if it has any movement, thats most likely your bad hub, and see if the wires are worn through or if the plug fell off the hub on all 4 wheels.
  9. #9 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    scottydoggs: my problem is that the trac control seems to be engaging all the time even when it says its off and the abs light is on.
    L36pro: ya i know i have to replaced the hub to fix it
  10. #10 Re: ABS and Trac Control off lights
    mine has the same problem right now, abs /trac off, and the traction control kicked on one time, check your hubs and wires or pay to have it scanned, if you have it scanned they will tell you exactly whats wrong with with it, could be another electrical part. but the hubs are the most likely source of the abs/trac off light.
  11. #11 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    ya ive spun the tires numerous times and it kicked in every single time
  12. #12 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    your right, no need to unplug anything. tell the dude your rearend that, because you were certain that the abs would not give you problems. lol
  13. #13 Re: ABS and Trac Control off lights
    Quote Originally Posted by L36pro View Post
    dude wtf are you talking about, stfu now! you know nothing over and over again!
  14. #14 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    no. it takes 2 seconds to unplug, your trac control will stop interfering with your driving and theres no risk of abs kicking in. but whatever, your risk.
  15. #15 Re: ABS and Trac Control off lights
    Jul 2008
    Tampa, FL
    sounds more like a tq management thing to me than a wheel speed sensor, but that's just me...stock pcm right?
  16. #16 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    unplug them and youll know for sure. scotty dogs is just arguing for the sake of it. how do you turn down such an easy diagnosis?
  17. #17 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    as far as i know its stock, just bought the car and it only had one owner with no noticeable mods. are you talking about torque converter vailskier3?
    im going to unplug the sensors in the morning to settle this between l36pro and scottydoggs lol
  18. #18 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    haha dont keep me in suspense.
  19. #19 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    lol i have no idea where generaly everyone is on this forum but im in ontario canada and right now its 12:15am and raining so ull have to wait till morning haha
  20. #20 Re: ABS and Trac Control off lights
    it could even be the electronic braking/traction control module, but its like 700 bucks new. but thats why having it scanned tells you whats wrong, and its not raining here. lol
  1. Hi im a newbie (2000 3.1 trac control and govener prob)
    By thegreenmachine in forum Introductions/Noob Questions
    Last Post: 01-09-2011, 12:19 PM
  2. 04 GTP Trac control
    By reddog in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2010, 12:13 PM
  3. ABS and Trac Control Lights On
    By itfrg in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2010, 03:07 PM
  4. trac control firing off
    By 04muscle in forum General Tech Discussion
    Last Post: 09-05-2009, 04:01 PM
  5. trac control
    By mileyguard in forum General Tech Discussion
    Last Post: 03-24-2009, 12:02 PM
