Thread: ABS and Trac Control off lights
Results 1 to 20 of 27
  1. #1 Re: ABS and Trac Control off lights
    Banned
    Apr 2011
    wv
    you cant just fix the sensor. the whole wheel bearing/hub assembly needs replaced on the bad side. take it to a brake shop and they will tell you which one is bad. then go to autozone and buy a new hub assembly. get the Timken, which is more expensive, because the bearing is smoother, the sensor is MUCH BETTER quality, and its made in the USA. the chinese bearings will go bad within the year you purchase them if your not EXTREMELY careful around potholes.
    one last thing, unplug your wheel speed sensors and the car will act normal. you will no longer have abs or trac control and the trac/abs lights will stay on. the brakes and gas pedal will function the old fashioned way, but at least you wont end up rearending some poor bloke because your ABS was keeping you from stopping.
  2. #2 Re: ABS and Trac Control off lights
    if your abs light is on already the abs is NOT WORKING NOW, no need to unplug anything.
    and the brake shop ain't going to scan your abs for free, its a $100 scan at best, unless you got a friend there. or you leave it there for them to fix it.
    jack up your car and see if you have the any play in the wheel by trying to move the wheel from 12 o'clock to 6 o'clock, if it has any movement, thats most likely your bad hub, and see if the wires are worn through or if the plug fell off the hub on all 4 wheels.
  3. #3 Re: ABS and Trac Control off lights
    Apr 2011
    Canada
    scottydoggs: my problem is that the trac control seems to be engaging all the time even when it says its off and the abs light is on.
    L36pro: ya i know i have to replaced the hub to fix it
  4. #4 Re: ABS and Trac Control off lights
    mine has the same problem right now, abs /trac off, and the traction control kicked on one time, check your hubs and wires or pay to have it scanned, if you have it scanned they will tell you exactly whats wrong with with it, could be another electrical part. but the hubs are the most likely source of the abs/trac off light.
  1. Hi im a newbie (2000 3.1 trac control and govener prob)
    By thegreenmachine in forum Introductions/Noob Questions
    Last Post: 01-09-2011, 12:19 PM
  2. 04 GTP Trac control
    By reddog in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2010, 12:13 PM
  3. ABS and Trac Control Lights On
    By itfrg in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2010, 03:07 PM
  4. trac control firing off
    By 04muscle in forum General Tech Discussion
    Last Post: 09-05-2009, 04:01 PM
  5. trac control
    By mileyguard in forum General Tech Discussion
    Last Post: 03-24-2009, 12:02 PM
