The crackhead way...aka hard as hell and overtorques a lug nut. Not recommended.
The next hardest way.
Easiest of the hard ways.
To further explain the second bolt thing to make sense. See where your passengerside dog bone bracket meets the coil pack bracket (just left of the oil fill cap). There is a second hole further back on that bracket from the two holes that the bolt is through. If you remove the bolts from that position on both dogbone brackets, then pull the motor slightly forward (you can use your hand on the SC snout) then put the passenger side bolt back in...but in the single hole of the bracket that is further back. If this doesn't make sense, I can get some pics/vid tonight for you.
If you want to easily rock the motor forward for backward, undo those bolts at the dogbones and on the driverside dogbone mount on the engine. Follow the mount to the LIM. If you lay a long screwdriver or prybar on that and hook the edge of the lim.. it's cake.
