Thread: Help!
Results 1 to 10 of 10
  1. #1 Help!
    GTP Level Member apierce1289's Avatar
    United States
    Ok so my 02 n/a 40th grand prix is giving me some issues. First off it just recently turned over to 100,000 miles. I have noticed that the car is very slugish at WOT and i think i may have heard it back fire once but im not to sure. The other thing is that if i WOT the car it will hold the gear for a bit and then i think it is going to shift but sometimes it will hold it longer than i thought it was going to. Just so you guys know i bought this car off of my nana so she took it to the dealer regularly and never beat on it. She was the only owner Also i have kept up with regular oil changes and use full synthetic. My first though is it could be a clogged CAT which would be an easy fix cause im putting SD headers on with the included race pipe. But other than that im out of ideas. If it helps my mods are cone intake on TB and dynomax mufflers. Headers aren't installed yet
  2. #2 Re: Help!
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Every seafoamed it or cleaned the TB?
  3. #3 Re: Help!
    United States
    Nope i never cleaned the TB but i have seafoamed it. The little butterfly piece in the TB looks shiny but do you think i should still take it apart? If so what parts will i need for taking it apart and putting it back on (like gaskets and stuff)?
  4. #4 Re: Help!
    Nov 2009
    The actual TB will look shiny on the one side but on the inside of the engine side will be dirty as hell. And for the seafoam did you just put it in your gas tank or did you do the 3 part/step seafom? and for the gasket for the TB I was able to reuse mine but my car is an 08.
  5. #5 Re: Help!
    United States
    I put some in the oil before an oil change and then some in gas tank. Then i put the rest in the brake booster line. Is there a write-up for cleaning a TB i have never done it before and i would like to clean it the best i can so my car will be working perfectly
  6. #6 Re: Help!
    Nov 2009
    Grand Prixs Of North America • View topic - clean your MAF & Throttle Body
    And you might as well clean your MAF while your at it. When were the spark plugs changed last?
  7. #7 Re: Help!
    United States
    Plugs i haven't changed, im waiting to do that when i do the headers. Also could someone give me a lesson on why a dirty TB would be bad lol?
  8. #8 Re: Help!
    Nov 2009
    It isn't bad, just a ton of built up carbon on it.
  9. #9 Re: Help!
    United States
    Come on people I really need some help with this I need more opinions!
  10. #10 Re: Help!
    Charles City, IA
    Your car has 100,000 on it, it needs a tune up. Pretty simple.
    SMGPFC Two Nipple General
