Thread: Stalling Issue's when starting!! Help!!!
Results 1 to 13 of 13
  1. #1 Stalling Issue's when starting!! Help!!!
    SE Level Member nickdemio's Avatar
    STL
    Well, just when i thought i had my engine under control..more problems arise. I have a 01 Grand Prix GT-3.8 (non-supercharged) and i was having problems with the MAF sensor...replaced it...codes & SES light went away. Now lately, when i go to start my car in the morning(usually kinda cold)..it starts..idles a lil high and dies out...repeatedly for a couple starts..and then on the last start it idles normal and its fine. But ive been noticing a a lil hesitation too sometimes coming off a stop sign or when accelerating quickly it will chugg a lil...and sometimes while driving and i speed up to pass somebody...the rpms will stick around 3k and then chugg into speed...smh..this is crazy tho..no service engine light or nothing. Also replaced the TPS sensor awhile back too..does anybody have any info on these type of issues????
    2001 GP GT
  2. #2 Re: Stalling Issue's when starting!! Help!!!
    STL
    And this issue dosent happen everytime i start it up in the mornings...jus every now & then..could it be a bad fuel filter/fuel pump..bad MAP sensor..or a bad CPS sensor..cause im lost! Bad wiring maybe...smh
    2001 GP GT
  3. #3 Re: Stalling Issue's when starting!! Help!!!
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Mine did this Chek out the fuel pump resistor. Next time it does this try this trick. Its bypassing it on the relay. Worked for me. If it cures it then you know what it is. 50 dollar part on GMpartsdirect.com and looks insanley easy to change I havent changed mine yet I just did the bypass. Heres a link to check out just bend the tab on the shown relay.
    L67-equipped cars: My car starts and then stalls. Repair inside..
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  4. #4 Re: Stalling Issue's when starting!! Help!!!
    STL
    Good looking..i'll keep this trick in mind...i also read it could be my MAP sensor...that will cause the car to stall after start up & said it acts as if its the fuel pump.
    2001 GP GT
  5. #5 Re: Stalling Issue's when starting!! Help!!!
    Oct 2008
    IL
    The MAP sensor could for sure I just gave this a shot because all you gotta do is bend a tab and it rules one thing out. needle nose pliers helped me a ton but I also have the hands of a 10 yearold girl.
  6. #6 Re: Stalling Issue's when starting!! Help!!!
    Ontario
    Any update on this? I was having the chugging and hesitation symptoms for a little while and today it stalled on me once while driving. After a few tries it did start again. Then I continued on my way to a few more stores. As I was leaving my last store it gave me the issues of starting up, but it did start.
  7. #7 Re: Stalling Issue's when starting!! Help!!!
    Quote Originally Posted by dmcglynn View Post
    clean the throttle body if its a 04+, otherwise the CPS can cause the stalling while driving issue
  8. #8 Re: Stalling Issue's when starting!! Help!!!
    Ontario
    Its an 01, so I will take a look at that.
    Thanks
  9. #9 Re: Stalling Issue's when starting!! Help!!!
    Oct 2008
    IL
    Have you tried to bypass the resistor yet???? Its a free shot in the dark
  10. #10 Re: Stalling Issue's when starting!! Help!!!
    Ontario
    man, there are so many little differences to everyones problem that make it difficult to figure out what my issue is!
    Plus, I can't do the work myself so I have to take it to a shop.
  11. #11 Re: Stalling Issue's when starting!! Help!!!
    Oct 2008
    IL
    Im just sayin its worth a shot because all it is, is bending on little metal tab in the fuse box on a relay. If it doesnt help. Bend it back.
  12. #12 Re: Stalling Issue's when starting!! Help!!!
    A good mechanic would diagnose it by looking at the last couple of weeks/things done to it.
    You said you replaced the maf. What brand maf? We commonly see cheaper replacement maf's like AutoJunk's go back quickly after being replaced.
  13. #13 Re: Stalling Issue's when starting!! Help!!!
    Ontario
    Well yesterday morning, I drove it for well over an hour hoping/trying to induce something so I could try the bypass....and of course it ran fine!
    Since I need my car for work I decided to take it in and let the shop diagnose and repair.
    I hadn't had the MAF replaced and that is what it was. I also have a bad O2 sensor and EGR calibration needs to be done. They said that they could move the MAF and make the car stall out.
    I didn't have the $1,000+ to do it all so I replaced the MAF(dealer part) to take care of the stalling. I will be out on the road a bit today, so it will be a good test.
    It also has an outstanding Recall to be done, so I will take it back for that and get the others done then.
    Until next time, thanks guys!
  1. Please help, 2000 Grand Prix starting/stalling problems
    By mjs173 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:22 AM
  2. yet another stalling issue
    By ginger1974 in forum General Tech Discussion
    Last Post: 07-04-2010, 09:20 AM
  3. Stalling Hot Issue Need Help...
    By BPGPSE in forum General Tech Discussion
    Last Post: 06-13-2010, 09:26 PM
  4. stalling after starting
    By cruse in forum General Tech Discussion
    Last Post: 02-24-2010, 10:25 AM
  5. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
