Thread: Stalling Issue's when starting!! Help!!!
Results 1 to 13 of 13
  1. #1 Re: Stalling Issue's when starting!! Help!!!
    SE Level Member nickdemio's Avatar
    STL
    And this issue dosent happen everytime i start it up in the mornings...jus every now & then..could it be a bad fuel filter/fuel pump..bad MAP sensor..or a bad CPS sensor..cause im lost! Bad wiring maybe...smh
    2001 GP GT
  2. #2 Re: Stalling Issue's when starting!! Help!!!
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Mine did this Chek out the fuel pump resistor. Next time it does this try this trick. Its bypassing it on the relay. Worked for me. If it cures it then you know what it is. 50 dollar part on GMpartsdirect.com and looks insanley easy to change I havent changed mine yet I just did the bypass. Heres a link to check out just bend the tab on the shown relay.
    L67-equipped cars: My car starts and then stalls. Repair inside..
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  3. #3 Re: Stalling Issue's when starting!! Help!!!
    STL
    Good looking..i'll keep this trick in mind...i also read it could be my MAP sensor...that will cause the car to stall after start up & said it acts as if its the fuel pump.
    2001 GP GT
  4. #4 Re: Stalling Issue's when starting!! Help!!!
    Oct 2008
    IL
    The MAP sensor could for sure I just gave this a shot because all you gotta do is bend a tab and it rules one thing out. needle nose pliers helped me a ton but I also have the hands of a 10 yearold girl.
  1. Please help, 2000 Grand Prix starting/stalling problems
    By mjs173 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:22 AM
  2. yet another stalling issue
    By ginger1974 in forum General Tech Discussion
    Last Post: 07-04-2010, 09:20 AM
  3. Stalling Hot Issue Need Help...
    By BPGPSE in forum General Tech Discussion
    Last Post: 06-13-2010, 09:26 PM
  4. stalling after starting
    By cruse in forum General Tech Discussion
    Last Post: 02-24-2010, 10:25 AM
  5. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
