Thread: Wipers will not work......
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Wipers will not work......
    Donating Users madpat's Avatar
    Apr 2011
    New York
    Multimeters run for around $15.
    Or, you can take it to your local car part shop and tell them what's up and they will most likely test it for you with one they have to see if you need a motor in which they will be pleased to sell you. :P
    I know Advanced Auto Parts always does minor stuff like this for customers.
    Representing the 315 - CNY!!
  2. #22 Re: Wipers will not work......
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    ok, I will run it up there then. Thanks for the help.. still feel free to chip in lol
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  3. #23 Re: Wipers will not work......
    You don't need a meter. Pull out a 194 from your turn signal, pull the tabs straight. Stick one wire into the ground and another into the power. Does the bulb light up?
    Yeah..I got an answer or redneck solition for everyting. Keep that bulb handy...we'll check your injectors next!
  4. #24 Re: Wipers will not work......
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Like stated above multimeters run around $15 but have seen some for $7. You will always want to have one cause they are a nice to have around.
  5. #25 Re: Wipers will not work......
    Jun 2010
    Indy
    So Auto Zone or Advance Auto would not test it. Sadly, I'm not rich, and I just don't have said money for a meter, not even $7 dollars.. I will call a friend and see if he has one, I think he might... Some random guy at auto zone said it sounded like the motor went bad... So who knows.. If my friend does not have one, I'll give the redneck method a try.. More than likely watch my car and me go:
  6. #26 Re: Wipers will not work......
    London Ont, Canada
    head to a junkyard and palm yourself some parts! lol
  7. #27 Re: Wipers will not work......
    Nov 2009
    Well if he does have a multimeter you can also test the motor to see if it is the motor itself. Multimeter would be your best bet IMO if you can get your hands on one.
  8. #28 Re: Wipers will not work......
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by GrandPrixSE View Post
    So today I go out and start my car, I notice the wipers move up from their off position like they were left on, but the switch was in the off position.... So I flipped it on, and nothing. I fussed with it for awhile, but gave up and went on to what I had to do. Thought it might fix when I turn the car back on next time, well no luck with that.
    Its supposed to rain for this whole week.... Does anyone know is wrong with them??? Possibly blown fuse??? The signals still work, and the wiper fluid still sprays and the brights work still, so I doubt its the lever...
    Mine does the same, and has done so since I got it (about a year ago). The wipers will randomly turn on when they get ignition power, then go right back to park. This only happens once in a while, so it isn't that big of a deal. Recently though, I've had the wipers on intermittent, and they will suddenly stop working. I can shut them off and they will park, or turn them on to hi, then back to intermittent and they will be fine. The other day, I lost all but hi, and as soon as I switched off of hi, the wipers stopped where they were. After some wiggling of the signal lever, they worked fine again.
    I am pretty sure my problem is the MFS (multi-function switch). Had similar problems with other vehicles and the MFS' wear out internally, usually the contacts.
    Being that the MFS is pricey, and I have other more important things to repair, I will keep pushing my luck and hope that they don't fail me for the next few months.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #29 Re: Wipers will not work......
    the light bulb is a simple test light. and free.
    Just saying... when all hell breaks loose, you use what you have handy because the majority of your tools are at home.
    One bulb, a couple pieces of wire and you have a perfectly fine tool that guys have used for years.
  10. #30 Re: Wipers will not work......
    Jun 2010
    Indy
    Funny thing, I have power going to the fuse and motor.. Because last night when I decided to flip the switch, they for some reason or another started working again.. o.O
  1. Windshield wipers
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-22-2011, 09:10 PM
  2. Wipers Help
    By shawnschuldt in forum General Tech Discussion
    Last Post: 12-18-2010, 12:53 AM
  3. Wipers don't work at all
    By kevinpope in forum General Tech Discussion
    Last Post: 09-12-2010, 01:10 PM
  4. wipers
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 03-11-2009, 12:58 PM
  5. how to fix wipers?
    By Dohner in forum General Tech Discussion
    Last Post: 03-07-2008, 04:35 PM
