Chainging out my daughter 00 gt fuel pump. I found a replacement from craiglist from a guy moding his 02.
I pull the dead one to realize it was a replacement with a different wiring harness. I was able to swap out the other connecter and solder the internal wires so they work (taped and shrinkwrapped).
Now the original fuel pump does sit down in the fkn hole enough to get the snap ring in place unless I remove the gasket.
Question: Do you think an rtv seal would be good enough? It would still be tight.
