Thread: performance shift
Results 1 to 20 of 23
Scott B performance shift 06-26-2008, 08:26 PM
archemedes Re: performance shift 06-26-2008, 10:19 PM
Preotic Re: performance shift 06-26-2008, 11:14 PM
TCO Re: performance shift 06-27-2008, 02:15 PM
IndeedSS Re: performance shift 06-27-2008, 03:18 PM
blowfishRus6 Re: performance shift 06-26-2008, 11:23 PM
GeddyLee Re: performance shift 06-27-2008, 12:59 AM
IndeedSS Re: performance shift 06-27-2008, 07:33 AM
GeddyLee Re: performance shift 06-27-2008, 07:51 AM
Sabrewings Re: performance shift 06-27-2008, 08:47 AM
Reptile Re: performance shift 06-27-2008, 09:38 AM
Myprixxx Re: performance shift 06-27-2008, 04:36 PM
Ninjo Re: performance shift 06-28-2008, 09:41 PM
Sabrewings Re: performance shift 06-28-2008, 09:49 PM
Ninjo Re: performance shift 06-29-2008, 07:26 PM
IndeedSS Re: performance shift 06-29-2008, 08:19 PM
IndeedSS Re: performance shift 06-29-2008, 08:37 PM
IndeedSS Re: performance shift 06-29-2008, 08:40 PM
  1. #1 performance shift
    Apr 2008
    Hampton, VA
    How do you click the performance shift on or is it a option thats not on every gtp. I can see it in my dash when the sun hits it just right. I don't see any buttons or any thing inside my car. Someone should write a book on modding
    this car. I live in a small town and must people here are all mustang guys.
    Thanks for all the help every one in this forum have been to me so far.
  2. #2 Re: performance shift
    Saraland Alabama
    it's on the shift knob on the gtp's (at least on mine)
  3. #3 Re: performance shift
    GT Level Member Preotic's Avatar
    Missoula, MT
    They don't have the performance shift after 99. However it's still in the pcm and it's still in the guages(location varies). You can ground a pin out on the pcm and you will have performance shift all the time or you can wire a switch to that pin and when you flip the switch you'll have performance shift. It's definately a must have. I know it's pin 21 but i can't remember if its the blue or clear connector. Find a writeup before attemtping this.
    Check for a button on the shifter if it's not there then you most likely have do what i described above.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  4. #4 Re: performance shift
    Quote Originally Posted by Preotic View Post
    Actually I believe the last year for performance shift was either 2000 or 2001. My 2000 GTP has it.
  5. #5 Re: performance shift
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Performance shift, with an untouched PCM only changes the line pressure and desired shift times. Meaning Performance shift mode is firmer and faster shifting. With a tuner you can also make differences in RPM shifting under WOT and Part throttle and MPH shifting, TCC lock/unlock etc.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: performance shift
    Donating Users blowfishRus6's Avatar
    g.a.
    is there a big difference in the performance shifting???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: performance shift
    St. Louis Mo.
    You will see the words PERFORMANCE SHIFT inside your DIC on most newer GPs. You have to turn on the settings in the PCM and get a shift lever that has the PS button on it or you can rig up a switch somewhere else on your console to make it work.
    The benefits are nice in the fact that you can have your daily driver tranny setup in nonperformance mode and then have your track or jackin around settings setup for when you select the Performance Shift mode.
    Its something well worth looking into. I made a write up for it on our how to section.
    http://www.grandprixforums.net/perf_shift.php
    James Shafer
    St. Louis MO
  8. #8 Re: performance shift
    St Louis MO
    Most people find performance shift settings great for daily driiving, and leave it on all of the time. I think having a switch though would be nice though.
    Do the OSID's on GTPs without Performance Shift have the Performance Shift tables setup up? On the Impalas, Performance Shift and Normal have identical values in the tables.
    Nevermind: I just looked at a stock 2002 GTP bin and they do have different values. The Performance Shift tables are not that aggressive, but they are different than Normal.
    2010 Camaro SS LS3
  9. #9 Re: performance shift
    St. Louis Mo.
    Quote Originally Posted by IndeedSS View Post
    Well yeah GM is not gonna put massively different settings in the peformance shift. I think they mostly took off the speed limiter, and changed some shift points to hint at more spirited shifting, but nothing crazy.
    Of course you are gonna seek out people in the community who have redone their tranny tunes and get their profiles to make a better performance shift tune. I have Chris O's tune he uses on his GTP, different shift points and such beyond what the stock performance shift has to offer
    James Shafer
    St. Louis MO
  10. #10 Re: performance shift
    Barksdale AFB, LA
    I like my more crisp shifts for normal driving. Less wear and tear on the clutches plus higher line pressure is a lower duty cycle (less wear) for the dreaded pressure control solenoid.
    2009 Subaru Impreza WRX STI
  11. #11 Re: performance shift
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by GeddyLee View Post
    Partially right. The speed limiter is set up in the spark and fuel tables, not the transmission settings.
  12. #12 Re: performance shift
    St. Louis Mo.
    Quote Originally Posted by Reptile View Post
    DOH! Spanks for pointing that out sir...........
    Speaking of spark................plugs......................
    James Shafer
    St. Louis MO
  13. #13 Re: performance shift
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    yeah i got ps too
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  14. #14 Re: performance shift
    SE Level Member Ninjo's Avatar
    Houston, TX
    if I was to end up having to do this ( id probably start w/ the switch then get the shift nob from PFYC.. but actually having a switch would seem pretty cool, ge one of those little ones from RS w/ the red cover ) but yea anywho back to the question.. would i HAVE to get an aftermarket PCM or would i be able to do the recalibration w/ the hand held.. and if so is it setup to automatically set the shift points to such as the earlier years? or would all that have to be tuned? cause i saw its ll the same just minus the shift button so i wonder how much calibration and setup would be needed. does it do exactly what the 99's and so on Performance shift does?! ( i know i asked like 2 questions twice lol)
    just curious to know what to expect
  15. #15 Re: performance shift
    Barksdale AFB, LA
    Like IndeedSS said, the cars that don't have performance shift wired usually have the same numbers in both the normal and performance tables. No sense in changing them if they can't be used, right?
    And what is "the handheld"?
  16. #16 Re: performance shift
    Houston, TX
    like a hand held tuner.
  17. #17 Re: performance shift
    St Louis MO
    The hand held tuners like Hypertech won't help you much. You need someone with a DHP PT to help you out. Give me a few minutes and I'll post the two tables at are different on a car with performance shift. Please note that even though there are only two tables changed on a stock PCM when you flip the switch, with a Tuner there are a few more rables that have the Normal and Performance Shift tables you can adjust.
    2010 Camaro SS LS3
  18. #18 Re: performance shift
    St Louis MO
    These are from my son's 99 GTP stock settings. These two tables are the only ones different from the factory.
    performance shift Attached Images
    2010 Camaro SS LS3
  19. #19 Re: performance shift
    St Louis MO
    If you have a tuner, some additional Normal and Performance Shift tables
    2010 Camaro SS LS3
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Performance shifting
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 06-01-2008, 08:58 PM
  3. Performance Chips???
    By philip09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2008, 04:19 PM
  4. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
