MAP...not MAF....biggggg difference there...
No pics, but if you look right under the supercharger snout, there will be a T with 3 vacuum lines on it. Cant miss it. Follow the vacuum line on the back side of the supercharger, and it will lead to your MAP sensor.
Pretty sure the Map sensor is held in place by 2 T30 security Torx bolts. (same ones all the throttle body sensors are held in by)
Alrighty...Mighty google might just help....heres a ghetto diagram...
You tap between where it says "Mass Air Pressure" and Connection Under Supercharger Snout"...hop that helps.
