Thread: Is this Fuel Filter for real? (So Stuck)
Results 1 to 13 of 13
chevyy1212 Is this Fuel Filter for real?... 04-20-2011, 04:54 PM
postalc38 Re: Is this Fuel Filter for... 04-21-2011, 11:58 AM
Bio248 Re: Is this Fuel Filter for... 04-21-2011, 12:19 PM
BillBoost37 Re: Is this Fuel Filter for... 04-21-2011, 12:26 PM
calvin Re: Is this Fuel Filter for... 04-21-2011, 06:31 PM
chevyy1212 Re: Is this Fuel Filter for... 04-22-2011, 05:38 PM
chevyy1212 Re: Is this Fuel Filter for... 04-22-2011, 05:42 PM
postalc38 Re: Is this Fuel Filter for... 04-22-2011, 08:39 PM
chevyy1212 Re: Is this Fuel Filter for... 04-23-2011, 06:35 AM
postalc38 Re: Is this Fuel Filter for... 04-23-2011, 07:37 PM
chevyy1212 Re: Is this Fuel Filter for... 04-23-2011, 07:43 PM
postalc38 Re: Is this Fuel Filter for... 04-24-2011, 06:06 PM
chevyy1212 Re: Is this Fuel Filter for... 04-24-2011, 07:11 PM
  1. #1 Is this Fuel Filter for real? (So Stuck)
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Honestly its the most straight forward thing to do. It will not budge tho(98 GS). Ive been spraying it for 4 WEEKS with PB blaster yes its rusted. I need options. Yes I have read all the threads on this I really dont want to pay a shop $40-$80 to do this but the track Im on Im going to snap the fuel line. The whole put some muscle into it has already been tried too.
    I had one shop tell me to use a torch........ Seems to be counter productive there with that option.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Is this Fuel Filter for real? (So Stuck)
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Do what I did on my Aurora: Say it screw it, go to the parts store and buy some replacement fuel line, a compression fitting, and flare/bend/cut tools and break the line off, then cut somewhere upstream to it.
    Mine was more of an emergency repair after I snapped the line at the filter, but it worked great for 2 years.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  3. #3 Re: Is this Fuel Filter for real? (So Stuck)
  4. #4 Re: Is this Fuel Filter for real? (So Stuck)
    What's rusted. The threaded end or the push on end? If the threaded end is rusted, hold the line/fitting and turn the filter.
    I know..i know..I'm a genius
  5. #5 Re: Is this Fuel Filter for real? (So Stuck)
    UNITED STATES
    Tis right here worked for me! Vice grip on the nut on the end, twist the filter by hand. Also, disconnect the clip end first, mine was getting hung up on that.
  6. #6 Re: Is this Fuel Filter for real? (So Stuck)
    Oct 2008
    IL
    I so wish this worked for me too. I tried that. I even took it to a shop today and they couldnt get it off. So 4 weeks of spraying it with PB and trying the 2 wrench way, then I tried spinning it by hand, then had a shop try and nothing worked. Im looking at the repair kit mentioned ^^. The first 20' from the filter could use some repair anyway from lovely Illinois rust. Im still open to ideas tho. Ill still give it another shot tho.
  7. #7 Re: Is this Fuel Filter for real? (So Stuck)
    Oct 2008
    IL
    Is flaring the end of the lines 100% needed? Shouldnt the fuel line repair kit do just fine. I mean the compression fittings should do the trick.
  8. #8 Re: Is this Fuel Filter for real? (So Stuck)
    No. If you just buy a section of replacement fuel line that is already flared at the end, you can just cut the line to desired length and use a compression fitting for the unflared side, then put an o-ring on the flared side and bolt on to the fuel filter there.
    This is my quick-fix job on my old Aurora....Was changing the filter a few hours before a 3 day vacation and snapped the line.
  9. #9 Re: Is this Fuel Filter for real? (So Stuck)
    Oct 2008
    IL
    Quote Originally Posted by postalc38 View Post
    You are like gold to me right now man. Thanks for the help. I got one from napa but to short for what I need. Either way your a good man pat yourself on the back for a job well done
  10. #10 Re: Is this Fuel Filter for real? (So Stuck)
    No problem, I know how daunting it is.......I think I had a mild stroke when my situation happened....that line snapped and i said F*** there's goes my vacation. lol.
    Hope it works great for ya!
  11. #11 Re: Is this Fuel Filter for real? (So Stuck)
    Oct 2008
    IL
    Im just going to use a mini pipe cutter I picked up today. Did you pop the line out of the clamp with all the other lines without an issue. I heard that theres a slight chance it can mess with the other lines. I just got a 40" piece came with th o-ring and flared end all the good stuff. It actually looks like a easy fix and will help with some of the crappy rusted fuel line in the process.
  12. #12 Re: Is this Fuel Filter for real? (So Stuck)
    I actually didn't have to pop it out, i used the cutter tool and cut the line right where it straightens out as it runs under the chassis, that way i avoided the clip all together and didn't have to worry about the compression fitting rubbing against the underbody.
  13. #13 Re: Is this Fuel Filter for real? (So Stuck)
    Oct 2008
    IL
    See I would go that route but my hard line right ther is sooo rusty by the filter that its about 20" back till theres a decent spot not all that rusty to tap into. Today I did my s/c coupler, open cone on the GS and an oil change on the GP so Im tapped out for today. Plus Lowes didnt have the mini cutter in stock since that was going to be todays project. I have a thing for Kobalt tools not clue why.
  1. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  2. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. Really need some help, stuck oil filter
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2010, 06:09 PM
  5. Really need some help, stuck oil filter
    Last Post: 05-22-2010, 09:51 PM
