Thread: Very weird engine temperature behavior...
Results 1 to 9 of 9
  1. #1 Very weird engine temperature behavior...
    SE Level Member T0pwater's Avatar
    SW Michigan
    Recently I removed my 180* T-stat for gas mileage purposes (stock car). I had used the 180 as a replacement for a 195 stat that was running below 170, thinking I'll need the 180 soon. Anyway, I took that one out and put in a new Stant 195 thermostat and this is what I'm getting:
    Temp will warm up like normal to around the 195* range (just before the middle of the gauge), then the t-stat opens and the temp comes down to around 180 - normal, right? Well, it never gets back up to 195. It just fluctuates around 180. This happened yesterday and today. If I sit in the driveway the temp will come up past 195 until the fans come on like it should. The problem only occurs if I'm moving. It's been 50 deg outside where I live.
    Yesterday I sat in the driveway and held the car at 2500 RPM until the temp was 210 for about 5 minutes, just to flush out any possible crud sticking between the thermostat plunger and the flange, thinking something got caught as it was shutting. Then, this morning, same problem. All my readings are just coming from the gauge... currently looking for a used scanner.
    Any thoughts? Did I get a bad t-stat?
  2. #2 Re: Very weird engine temperature behavior...
    that fans are turning on in the range for a 180* thermostat.
  3. #3 Re: Very weird engine temperature behavior...
    And did you bleed all the air out of the system?
  4. #4 Re: Very weird engine temperature behavior...
    SW Michigan
    What do you mean? The PCM is stock.
    Today on the way home from work it only got to 190 before coming back down to 180. I'm thinking the stat may be crap.
    Fill process:
    Filled coolant w/ bleed screw off, started engine, topped off rad, closed bleed screw, closed cap, ran to temp, turned off engine. Made sure overflow was full enough (went down a lot during cool-down) then topped off rad and overflow again after engine cooled.
    I just went out and squeezed the upper rad hose with the bleed screw off and coolant immediately came out (no air space). I've run it constant at 210 in the driveway, so I'm assuming any air has been pushed out.
    I guess next step is replacing the thermostat. Anyone else have a problem like this with a new t-stat?
  5. #5 Re: Very weird engine temperature behavior...
    when you bleed it, you need to run the car till its hot with the rad cap off, and wait till the t-stat has opened up, open the brass screw, don't remove it, 2 or 3 turns, it will blow bubbles if it has air in it, when a steady stream of coolant comes out shut the screw, then top off the rad, and cap it. oh and put a 195 t-stat in it if you swapped it back to a 180, your not tuned for a 180 and you don't need it.
  6. #6 Re: Very weird engine temperature behavior...
    SW Michigan
    Exactly. I realized I wouldn't tune for a while, so I have the 195 in there now - this is the one giving me problems.
    Also, whenever I try to let it run with the cap off, the coolant comes up too fast and I have to put the cap on to keep it from pouring out. I can try letting some coolant out and doing this, but wouldn't running it above the t-stat temp flush all the air out to the rad? I mean, 10 mins at 210, all the air will blow out and collect in the rad one way or another. Right?
    That's what I did and I'm assuming I got all the air out, albeit not the common way. I can see how a pocket could get trapped in the upper rad hose, but I just checked for that and the coolant was right up to the bleed screw.
  7. #7 Re: Very weird engine temperature behavior...
    have you checked the water pump yet? like pull the belt and see if it spins freely and has no play in it it, try to move it from the top of the pulley to the bottom, as to check the bearing.(wiggle it side to side)
    mine never over flowed out the radiator, only if you rev the engine while its open will it over flow. and if you grab a hose and punch it tight can you feel coolant moving past the pinch point? when the cap is on.
    and have you replaced the rad cap yet? check the outlet of the radiator to the hose that goes to the reservoir, check to see if its sludged up, and hows the hose to reservoir tank and is it filled to the full line?, it needs to be air tight, no cracks or broken plastic at the cap of the reservoir tank.
    thats about all i can think of at this time.
  1. Erratic Boost and other odd behavior
    By tpboyce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2010, 09:54 PM
  2. What is the normal engine temperature?
    By noname in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 07:37 PM
  3. weird noise from engine
    By carl06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2009, 06:50 AM
  4. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  5. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
