Thread: hub/bearings/breaks?? Help Please
Results 1 to 9 of 9
jayson14 hub/bearings/breaks?? Help... 07-13-2010, 09:53 PM
kjohnson Re: hub/bearings/breaks??... 07-13-2010, 10:50 PM
jayson14 Re: hub/bearings/breaks??... 07-13-2010, 10:55 PM
E90 87SS GTP Re: hub/bearings/breaks??... 07-13-2010, 10:59 PM
jayson14 Re: hub/bearings/breaks??... 07-14-2010, 07:29 AM
Tarmac Wizard Re: hub/bearings/breaks??... 07-14-2010, 09:26 AM
jayson14 Re: hub/bearings/breaks??... 07-14-2010, 09:32 AM
sic6 Re: hub/bearings/breaks??... 07-14-2010, 10:40 AM
dorkfish Re: hub/bearings/breaks??... 04-10-2011, 05:52 PM
  1. #1 hub/bearings/breaks?? Help Please
    Jul 2010
    indiana
    on my 2001 grand prix se i was hearing a loud humming and it got worse with time. eventually it felt like it was holding up the car. like i was pulling a trailer or something.
    I was told it was the bearings on the drivers side. Car sat in garage for a few weeks and yeaterday i discovered this site. I found an excellent post with pics on how to change hub/bearingd assembly. Needless to say i got that done a few minutes ago, went for a ride and it didnt fix a thing. i did notice in my short ride around the block everything including rim was extremely hot. i went to passenger side just to see and it wasnt even warm. Any ideas on what it could be would be is greatly appreciated.
    thnaks
    jayson
  2. #2 Re: hub/bearings/breaks?? Help Please
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    brake might be hanging up. is it pulling to one side?
    silver 2003 Grand Prix GT List is on it's way to be updated
  3. #3 Re: hub/bearings/breaks?? Help Please
    Jul 2010
    indiana
    nah, i dont feel any type of pull to one side or another. the longer i drive i notice i need more gas just to get it going. for example, if i start it up it will move forward if i put her in drive and let it just idle. then after a couple minutes of driving it wont budge and is extremely hot.
  4. #4 Re: hub/bearings/breaks?? Help Please
    SE Level Member E90 87SS GTP's Avatar
    NJ
    jack the front end up and see if the wheel spins freely, must put in neutral and put blocks on rear tires + e brake... Did changing the bearing get rid of the humming?
  5. #5 Re: hub/bearings/breaks?? Help Please
    Jul 2010
    indiana
    humming was stil there. I will try this when i get home. what does it mean if the wheel wont spin?
    also, the ABS light has been on.
  6. #6 Re: hub/bearings/breaks?? Help Please
    Jun 2010
    Wellesley
    Quote Originally Posted by jayson14 View Post
    sounds to me like the brake caliper might be seized, especially if you're notice enough of a problem that's hindering performance but I'd be surprised that you wouldn't notice a problem when you were replacing the hub bearing assembly
    TW,
    Discount Auto Parts | New Auto Parts - Buy Automobile Parts at Discount Prices
  7. #7 Re: hub/bearings/breaks?? Help Please
    Jul 2010
    indiana
    Quote Originally Posted by Tarmac Wizard View Post
    TW,
    i really have no idea what im doing. Money is extermely tight and this is the 1st repair besides pads/rotors that i have ever tried. What could i have missed with the caliper??
  8. #8 Re: hub/bearings/breaks?? Help Please
    GT Level Member sic6's Avatar
    san marcos, tx
    If the wheel is getting hot to the touch then the brake caliper on that side is not releasing fully. It could be a defective caliper itself, worn or stuck guide pins. Also could be a partially clogged brake hose at the caliper not letting fluid return back to the reservoir. Do as stated in the previous post to check to see if its binding up.
  9. #9 Re: hub/bearings/breaks?? Help Please
    Apr 2011
    wisconsin
    is it possible you tightend the axel nut too much ,, did you ever het this resolved?
  1. Rear Breaks
    By 1996pontiac in forum Brakes/Suspension/Chassis
    Last Post: 03-28-2010, 10:53 PM
  2. Another Toyota breaks loose on the freeway
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 03-20-2010, 01:25 PM
  3. Smoke Coming out Of my breaks?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2009, 05:34 AM
  4. Does it make sense to rebuild it before it breaks?
    By Burbman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 04:39 PM
  5. Less Breaks at work???
    By offroadfury6 in forum The Rant Forum
    Last Post: 10-30-2008, 06:16 AM
