Thread: no horn
Results 1 to 6 of 6
waltvmac no horn 04-07-2011, 03:57 PM
Explicit_Spade Re: no horn 04-07-2011, 03:59 PM
machinegunsquid Re: no horn 04-07-2011, 04:49 PM
SeanGTP Re: no horn 04-07-2011, 04:53 PM
csssaint12 Re: no horn 04-07-2011, 05:01 PM
waltvmac Re: no horn 04-10-2011, 07:25 PM
  1. #1 no horn
    Apr 2011
    The horn stopped working in my 2006 GP. I brought it to the shop and they replaced both horns at a cost of $272. That was just 3 months ago, and now it has stopped working again! Does anyone know of any common problems that I should be looking for? I had the cruise control replaced about 6 months ago and I am inclined to think that the horn wiring in the steering column was messed up at that time.
  2. #2 Re: no horn
    Omaha, NE
    Fuse?
  3. #3 Re: no horn
    Florida
    Check the fuses first..since that's the easiest thing to do. If the fuses are fine, take it back to the shop, and tell them that the problem that they fixed, has occured again.
    Since it's been such a short amount of time, they should do it for free.
  4. #4 Re: no horn
    Nov 2008
    Waterloo, Iowa
    Check the fuses, then check voltage to the actual horn while someone else presses it. Also that's too much for a horn. Horns are cheap, and easy to replace, like $15-30 bucks or so. Never spend that much on a horn again. :P
    But horns are two pieces, so it's unlikely both broke at the same time, which points more towards your wiring/fuses.
  5. #5 Re: no horn
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Not to be redundant but check the fuse. If your vehicle is the same as mine it should be located on the bottom right side that is a 15amp fuse and is between relays.
  6. #6 Re: no horn
    Apr 2011
    Thank you all for the response to my 'no horn' message. The horn is working now and didn't have to return to the shop. I just took the fuse out, it looked fine, put it back, and the horn started working. I'm just going to leave well enough alone and not investigate any further. For now I'll just keep my fingers crossed on this one. Thanks again.
  1. Horn
    By 400kmtd in forum Introductions/Noob Questions
    Last Post: 09-16-2010, 11:54 PM
  2. Horn?
    By Louie3 in forum 04+ Specifics
    Last Post: 05-10-2010, 10:32 PM
  3. Horn
    By RedBarron in forum Introductions/Noob Questions
    Last Post: 02-18-2010, 09:06 PM
  4. Horn Help
    By PhilsGTX in forum General Tech Discussion
    Last Post: 03-07-2009, 10:03 PM
  5. Horn Going off
    By Bruteforce72 in forum General Tech Discussion
    Last Post: 01-12-2009, 01:47 PM
