If the wheel is getting hot to the touch then the brake caliper on that side is not releasing fully. It could be a defective caliper itself, worn or stuck guide pins. Also could be a partially clogged brake hose at the caliper not letting fluid return back to the reservoir. Do as stated in the previous post to check to see if its binding up.![]()
