Thread: domelights will not work need help
Results 1 to 9 of 9
  1. #1 domelights will not work need help
    Indiana
    I have a problem. My dome lights refuse to work. Checked the fuses
    and the bulbs all look ok. I even went as far as to disassemble the BCM to see if anything looked burnt. Any ideas
    Also forgot to mention. before they stopped working completely they would intermittently stop then come on very dimly then go off and on (dimly) then off and so on and so forth and the radio would follow suite. but it was doing that regardless of if the doors were open or closed or switch was on or off. re wired radio to sunroof fuse (i have no sun roof hints no need for the fuse there) but still no dome lights. any ideas. like i said above the BCM motherboard looks free of burns so i am lost
    1997 Pontiac Grand Prix GTP SUPERCHARGED Black with Blackouts
    1996 Pontiac Bonneville Under Construction. Soon to be supercharged along with a little extra :P
  2. #2 Re: domelights will not work need help
    Indiana
    any body have any ideas where to starts?
  3. #3 Re: domelights will not work need help
    MI
    Check ground paths, voltages. Sounds more like a grounding problem to me than voltage.
  4. #4 Re: domelights will not work need help
    Indiana
    I have no clue where to look I really don't lol you'll have to guide me
  5. #5 Re: domelights will not work need help
    Indiana
    Guys I really need some helP... You guys are my last hope I have tried everything... Please someone help me figure this out
  6. #6 Re: domelights will not work need help
    by chance have you checked the fuse panel for power at the fuse? maybe the wires are loose where they plug in or burnt up.
  7. #7 Re: domelights will not work need help
    Indiana
    List all the fuse numbers I need to check please
  8. #8 Re: domelights will not work need help
    if you have a cover on the fuse box it should list what everything is, i drive a regal so i couldn't tell you for sure., check the fuse box under the hood too, should be a list of whats, what under the cover there too.
  9. #9 Re: domelights will not work need help
    Indiana
    SOLVED. I inspected the fuse with a magnifying glass and found that it had in fact blew. Thanks guys
  1. My Day At Work...
    By jerZcavy4120 in forum The Rant Forum
    Last Post: 04-05-2011, 10:03 PM
  2. will this work?
    By gtcoup in forum General Tech Discussion
    Last Post: 01-05-2011, 08:59 PM
  3. will this work...
    By Myprixxx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2010, 05:17 PM
  4. Does this work?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2010, 07:16 PM
  5. cant get sub to work
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 04:27 PM
