Thread: cant get sub to work
Results 1 to 7 of 7
CMURDAx cant get sub to work 01-16-2010, 12:10 AM
gtpinsc Re: cant get sub to work 01-16-2010, 12:39 AM
matt5112 Re: cant get sub to work 01-16-2010, 01:28 PM
MrTube Re: cant get sub to work 01-16-2010, 03:32 PM
CMURDAx Re: cant get sub to work 01-16-2010, 03:35 PM
gtpinsc Re: cant get sub to work 01-16-2010, 04:09 PM
MrTube Re: cant get sub to work 01-16-2010, 04:27 PM
  1. #1 cant get sub to work
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    Ok so i installed my new in-dash dvd player tonight and after some fiddling around i got the speakers to finally work. but i cant get my subwoofer to turn on. my amp and cap turn on but there is no sound coming out of the sub. on my deck there is a brown subwoofer out rca. but its only one, and then theres the front and rear red/white rca outs. and aux outs. i tried every combination to try and get this work and no luck. any suggestions?
  2. #2 Re: cant get sub to work
    Jul 2008
    sumter,south carolina
    subs new or used?
    02 GTP with mods 05 GP for DD
  3. #3 Re: cant get sub to work
    First off, subs have no on/off switch.
    If your amp turns on, then make sure the RCA is hooked into the RCA IN on your amp, not the OUT.
    If that doesnt solve it, try cranking it up, does the sub MOVE at all?
    If no, is the sub a dual voice coil sub?
    If yes, read this: http://www.grandprixforums.net/f41/w...snt-24538.html
  4. #4 Re: cant get sub to work
    New Jersey
    The subs can also be tested quick and easy by touching a 9V battery across its terminals for a brief second WITHOUT it connected to the amp, it should make a pop\thump sound and move a little.
    This is a good trick to polarize speakers as well if your not sure how their wired.
  5. #5 Re: cant get sub to work
    Toledo, Ohio
    Ok sub is used nd I know it works had it hooked up before and it pounded. RCAs are ran from the front speakers out of the RCA on the deck and the in on the amp. It only hits when I have my music blasting to the point where I cnt hear. Nd even then it's not very loud. I'm thinking about splicing my RCA back in to where it was when I had my factory head unit. Anyone else ever have this problem? I have a Bose stock system btw with a kicker l7, boss 3600w amp, 2farad cap, and an xovision in-dash DVD
  6. #6 Re: cant get sub to work
    Jul 2008
    probably a wiring issue... retrace all ur wires make sure they are hooked up properly. inspect rca's make sure they dont have any damage.
  7. #7 Re: cant get sub to work
    New Jersey
    does the amplifier have any input level controls. make sure they are turned up, check the level output on the head unit as well.
  1. Will these work??
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 09-28-2009, 08:00 PM
  2. Will this work on my 07 GP?
    By tino153 in forum General Tech Discussion
    Last Post: 05-28-2009, 04:07 AM
  3. Will this work??????
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2008, 08:40 AM
  4. Work
    By TheOtherNick in forum The Rant Forum
    Last Post: 10-14-2008, 09:30 PM
  5. G.I. In Fab work
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 06-27-2008, 10:33 AM
