Thread: Alarm problem 98 grand prix
Results 1 to 5 of 5
  1. #1 Alarm problem 98 grand prix
    winnipeg
    I recently lost my other set of keys that had the remote to unlock and lock my doors, now when i use my key to manually open the door the car alarm goes off. I can start the car but the engine quickly cuts out so its not the immobilzer in my car its the factory car alarm. does anyone know how to disable the car alarm or fix it so it doesnt go off when i manually open the door so i can drive my car again
  2. #2 Re: Alarm problem 98 grand prix
    Do you have the factory plus another alarm? Almost sounds like you have a second one and it's hooked into the factory alarm. You'd probably need to unhook that connection to get it to work. Try pressing unlock once you have the door open and see if the issue persists when you do that. I read up on an interfacing post at one point that said you can turn on/off the factory alarm in some manner like the lock/unlock.
  3. #3 Re: Alarm problem 98 grand prix
    winnipeg
    Don't have a second alarm and this did not work
  4. #4 Re: Alarm problem 98 grand prix
    winnipeg
    i have also located and turned off the valet switch still no luck
  5. #5 Re: Alarm problem 98 grand prix
    Akron Ohio
    Quote Originally Posted by darkpavilion View Post
    There is no valet switch on the stock alarm.
  1. Problem with 95 Grand Prix SE
    By heavenswindows in forum General Tech Discussion
    Last Post: 11-23-2009, 03:54 PM
  2. '99 alarm problem
    By underdog in forum Audio, Security & Visual Electronics
    Last Post: 11-07-2009, 11:28 PM
  3. Attempting to install a Omega K9-150 Alarm System in 97 Grand Prix
    By BlaqqMuzyk in forum General Tech Discussion
    Last Post: 09-15-2009, 07:28 PM
  4. '98 GTP wont start - alarm problem?
    By quadratokn in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2009, 02:42 PM
