Jack up the car and remove the drivers side wheel...when I changed the trans mount I used a 2x4 that is about a foot long...just make sure it is centered on the jack and you slowly run it up to the right (drivers side) of the transmission pan...also...unbolt both of the dog bones if you didn't do that. Once the dog bones are removed and the jack is just touching the transmission...unbolt the 4 15mm nuts that hold the transmission mount on...you might have to remove the plastic wheel well flashing...I just threw mine out...it gets in the way. Then...slowly jack up the transmission until you have just enough room to remove the mount and slide the new one in...then reverse.
