Thread: wiindow problem
Results 1 to 6 of 6
  1. #1 wiindow problem
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    my driver side window will go down but not up. it sometimes goes up a little bit but i usually have to pull it up, then it wont let me, ill push the up button, pull it up more, push it again, pull it up more and so on. my dad thinks its knocked off the track cause i can tip it forward out of the b pillar, i think its the window motor. i just dont see how it would go down but not up if it was knocked off track. ideas and thoughts?
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: wiindow problem
    Waukesha, WI
    well if its really hard to pull up that could be a possiblilty that it fell off the front track. most likely its the motor or regulator and the up pull cable is stretch. mine did that then one day the cable completely snapped.
  3. #3 Re: wiindow problem
    Nov 2009
    Milford, CT
    i can pull it up with ease once i hit the button, it like by hitting the button it allows it another couple of inches to be pulled up, and it pulls up easy. is there anyway to check which it is? i dont wanna spend money sht i dont need
  4. #4 Re: wiindow problem
    Waukesha, WI
    hmm try lubing the tracks then
  5. #5 Re: wiindow problem
    SE Level Member Trump's Avatar
    Tennessee
    GM regulators seem to have a lot of issues. I have changed several of them out as the cables and cable guides seem to give out or get twisted. I worked at one of the facilities that made the window regulators. As mentioned some of the window guides can cause a problem, but that normally does not happen that I have seen unless something else has caused the issue. You can remove the whole regulator and check it out or remove the window and check out the regulator and window guides pretty easily on most GM cars.
    If your window goes down and not up? I would take the door panel off and check things out, get the window up and then take the bolts out that hold it if you have that type or loosen the bolts on the clamp and take the window out and see if the regulator moves up and down OK. Just sounds to me like a regulator bad.
    PS: watch what you lube it with if you decide to lube it.
  6. #6 Re: wiindow problem
    Tennessee
    I may have missed it, but I did not see posted the year of car you have with the Window Regulator issues. I know the Pontiac grand Am in some years has the scissors type non cable system " piece of crap " in my thoughts. Put your window down about half way and then try and pull up on it with a little effort, see if the window comes up or if it seems fixed. Let me know what you find out and I am sure I can help you out.
  1. o2 problem!!
    By Cory in forum General Tech Discussion
    Last Post: 07-13-2010, 09:47 PM
  2. New problem!!!
    By chunk88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2010, 01:18 PM
  3. Egr problem
    By silvermistgt2002 in forum General Tech Discussion
    Last Post: 04-16-2010, 09:33 PM
  4. Problem With BBV
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 01:22 PM
  5. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
