Thread: Is it an electrical nightmare?
Results 1 to 18 of 18
  1. #1 Is it an electrical nightmare?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So I just picked up a 97 GTP and on the second day of owning it one of the head lights go out. Nothin big right? But I did notice my high beam light come on but dim, not as bright as when the high bean is actually on? Im assuming this is a computer signal to the driver?
    A day or two later the second head light goes out before I can replace the first one and now all my lights do not work. Head lights and fogs? Both of the fuses are still good. I have yet to replace the head lights which im going to do but wanted to get initial thought if anyone knew of this issue personally?
  2. #2 Re: Is it an electrical nightmare?
    let's toast til we die brand121's Avatar
    South Carolina
    Could very well be a bad ignition switch... as far as one going out and then the other, not sure...
    My couch pulls out, but, I don't...
  3. #3 Re: Is it an electrical nightmare?
    St. Cloud, MN
    I'm guessing you have a short somewhere.
  4. #4 Re: Is it an electrical nightmare?
    Never Never Land
    check your grounds...my brothers old gp would have intermittent starting problems cuz of a bad ground.
  5. #5 Re: Is it an electrical nightmare?
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    sounds like a bad ground. check your battery, check your bulbs by ohm'ing through them.
    <MiZzBeCcA>its not rape if you yell suprise
  6. #6 Re: Is it an electrical nightmare?
    Marysville WA
    Thanks for the replies guys. So consensus is a bad ground, is their a series of test I should do?
    I will start by checking the battery but where should I go from their?
    I did notice the autolights turning on and off when I did first get it? As in when the light outside was dim enough the lights normally kick on, but mine kicked on and off all day long? I do live in Seattle where lately its been very dark and gray outside so I chalked it up to that but if that info makes a difference im not sure?
  7. #7 Re: Is it an electrical nightmare?
    Never Never Land
    cloudy conditions can do it...mine do it too....theyll randomaly turn on and off on cloudy days.
  8. #8 Re: Is it an electrical nightmare?
    Jul 2010
    Las Vegas, NV
    let us know what you find. overcast turns my lights off and on quite frequently too.
  9. #9 Re: Is it an electrical nightmare?
    Marysville WA
    Well I think the cloudy conditions were causing it to act up a little bit but hard to say cause my 01 has never done this?
    I have determined by doing some troubleshooting that the fogs still work like when I chirp the alarm and on certain conditions of the ignition being on. Only when the car engine is off but all aux is on and power is running does the fogs work.
    I pulled apart my headlight assembly and replaced the headlight bulb and that did not fix it so im going to move on to checking grounds. Should I start by pulling the main battery ground and wire brushing it even though the car still powers on and runs everything else just fine? Or do I need to locate the headlight grounds?
    I can tell this is going to be quite the mystery
  10. #10 Re: Is it an electrical nightmare?
    Never Never Land
    check and clean any grounds you find....i'd use some sandpaper...IMO finer grit works better for this kind of thing.
  11. #11 Re: Is it an electrical nightmare?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i'd pull the battery terminals first...clean them with a wire brush. I could BARELY see any battery acid on my terminals one day and my car wouldn't even start!!! cleaned them no issues...
    Also don't forget to check your connectors sometimes some cars have corriosion issues inside of those, electrical contact cleaner is handy and won't hurt a bit...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  12. #12 Re: Is it an electrical nightmare?
    Marysville WA
    @ 4THGENCAMAROFAN
    So I am assuming by cleaning any grounds I see, ya mean that any black wires screwed to metal parts I should check out and clear? Cause I am seeing quite a few.
    @ offroadfurry6
    So even a slightly corroded battery ground could wig out a specific component while the rest of the car still works?
    I am goin to hit both of these issues tonight and let ya guys know how it turns out thanks again and keep the thoughts comin!
  13. #13 Re: Is it an electrical nightmare?
    Never Never Land
    ya grounds are usually black...there's usually quite a bit of them...what i would do is pop out your headlights and then trace the wires...youve got to fidn a ground somewhere.
    I know on my 97 theres a ground on the front of the radiator support more toward the driver side.
  14. #14 Re: Is it an electrical nightmare?
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by h0wl0ngcanitbe View Post
    @ 4THGENCAMAROFAN
    @ offroadfurry6
    with Eletricity...Anything can happen...ANYTHING...dude I had Full HID's and interior lights were working feriously but wouldn't start...nothing...cleaned the ground and fired right up...Eletrical components are funky, it can cause some weird effects...not saying ur issue is the ground...but cleaning the terminals is tooooooo easy and is a great place to start...no fix? move on to the other guys, find the headlight ground on the chasis somewhere, make sure it's making a solid connection, that means no grease or dirt/grime under or around it...
  15. #15 Re: Is it an electrical nightmare?
    Marysville WA
    Thanks for those comments guys I didnt get a chance to get to it today but will try to revisit it tomorrow and let ya know how it goes.
  16. #16 Re: Is it an electrical nightmare?
    GT Level Member njbrain's Avatar
    Rhinelander WI
    Gm released a TSB for certain '97 models that had to sensitive of a sensor. I don't recall what the fix was, but I'm sure it is floating around somewhere in cyberspace.
  17. #17 Re: Is it an electrical nightmare?
    Marysville WA
    TSB is the sensor on the dash that regulates the lights goin on and off correct? The two bulb modual one red the other one clear on the top middle of the dash?
  18. #18 Re: Is it an electrical nightmare?
    Marysville WA
    My two GTPs thank god for having spare parts
    The Ghetto hacked wireharness
    The way the stock ones that work look, and should look
    So I isolated the issue. The previous owner must have ghetto hacked some HIDs or something cause I swapped out my 01 lights with the malfunctioning 97 and they worked just fine. So for now I have disconnected the head lights and that freed up my fogs so that I have at least some lighting forward. All of the forward lights must be connected somehow?
    Here are some Pics
    So that brings a close to this thread and on to my next... Aftermarket Headlights!!
  1. Need some electrical help
    By Green97GTP in forum General Tech Discussion
    Last Post: 08-17-2010, 07:28 PM
  2. Electrical!!!! HELP
    By gtpman in forum General Tech Discussion
    Last Post: 11-08-2009, 06:42 PM
  3. Electrical
    By Brandan2670 in forum General Tech Discussion
    Last Post: 03-30-2009, 01:52 PM
  4. Electrical
    By 97gp97 in forum General Tech Discussion
    Last Post: 11-10-2008, 04:02 PM
  5. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
