sounds like a bad ground. check your battery, check your bulbs by ohm'ing through them.
Thanks for the replies guys. So consensus is a bad ground, is their a series of test I should do?
I will start by checking the battery but where should I go from their?
I did notice the autolights turning on and off when I did first get it? As in when the light outside was dim enough the lights normally kick on, but mine kicked on and off all day long? I do live in Seattle where lately its been very dark and gray outside so I chalked it up to that but if that info makes a difference im not sure?
cloudy conditions can do it...mine do it too....theyll randomaly turn on and off on cloudy days.
