Thread: ok what is going on???? lean or rich?
Results 1 to 10 of 10
  1. #1 Re: ok what is going on???? lean or rich?
    Fuel smelling oil is bad. Probably means you've smoked a piston or ring.
    As for lean, yeah, you are lean if your manis are glowing. That's bad btw and I'd suggest fixing the major vacuum leaks etc quickly. Do you have a maf screen in the TB?
    Keep running like you are and you'll be replacing a motor soon.
  2. #2 Re: ok what is going on???? lean or rich?
    TAKE THAT PULLEY OFF. and get a 3.4 instead.
    I would not even drive it till the headers come in. And get a better tune than ZZP.
  3. #3 Re: ok what is going on???? lean or rich?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    snip-
    ^this, or even back to stock..
    glowing because they're too hot. all that hot exhaust needs to goooo
  1. why do my ltft's go rich when hot?
    By Lawngoose in forum PCM Tuning
    Last Post: 08-12-2010, 04:42 PM
  2. rich idle, lean when high rpm and knock?
    By copperpacecar in forum General Tech Discussion
    Last Post: 07-30-2010, 03:24 PM
  3. Rich vs Lean
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 05-23-2010, 11:39 AM
  4. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
