Thread: Delete please
Results 1 to 20 of 21
  1. #1 Delete please
    SE Level Member GTPontiacMan's Avatar
    Dec 2010
    TX
    Delete please
    Last edited by GTPontiacMan; 01-11-2011 at 12:21 PM. Reason: DELETE THREAD, THANKS
  2. #2 Re: New Member Need Assistance Clicking Noise?
    Jul 2008
    sumter,south carolina
    sure its not coming from the axle?
    02 GTP with mods 05 GP for DD
  3. #3 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    I'm definitely sure it's not. I searched Google and found other with the same problem. But no solutions as of now.
  4. #4 Re: New Member Need Assistance Clicking Noise?
    Jul 2008
    is it steering involved or does it just click when ur in gear at idle? better description plz.
  5. #5 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    When the car is on or if I'm driving it makes a clicking noise like if the blinker is on but its a lot faster. I'm not sure if it may the be the multifunction switch. The noise is definitely coming under the steering wheel. But when I turn on the blinker or the hazard lights the clicking noise stops.
  6. #6 Re: New Member Need Assistance Clicking Noise?
    Jul 2008
    hmmmm thats weird... ive owned 2 97-03 body styles and never had this issue.. im sure someone else will chime in and help u with the issue though.
  7. #7 Re: New Member Need Assistance Clicking Noise?
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    It may be a "box" that is under your glove box, mine has a clicking noise as well, I disconnected that "box" I don't even know what it is lol, but it didn't hurt anything, I just disconnected and the noise stopped. Your noise may be different tho, but you can always try
  8. #8 Re: New Member Need Assistance Clicking Noise?
    Nov 2010
    new york
    i have your same problem.. i just have no idea what it is
  9. #9 Re: New Member Need Assistance Clicking Noise?
    Under your glove box, (not inside) look for a silver "box" that looks like an amplifier (kinda) I disconnected that one and that clicking noise stopped, your noise may be different tho, just trying to help
  10. #10 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    Quote Originally Posted by Haulero View Post
    The glove box on the passenger side? The noise in my car is coming from the driver side under the steering wheel. Where was the noise in your car?
  11. #11 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    Quote Originally Posted by whereswaldo01 View Post
    Is the noise coming from the driver side like mine?
  12. #12 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    I appreciate the help, I really do. Is the box located on the driver side or passenger side the noise your car was making?
  13. #13 Re: New Member Need Assistance Clicking Noise?
    Quote Originally Posted by GTPontiacMan View Post
    No, mine was on the passenger side. It may be a different noise cause when my car was making that weird clicking noise was coming from under the glove box in the passenger side. So your problem is different if it comes from the driver's side
  14. #14 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    Yeah driver side. It comes and goes. It gets annoying. I have to blast the radio. Need to figure it out. Thanks anyways.
  15. #15 Re: New Member Need Assistance Clicking Noise?
    Akron Ohio
    hmmm I think it might be the daytime running light box.
  16. #16 Re: New Member Need Assistance Clicking Noise?
    Akron Ohio
    Try the plug in the heat sink behind the removable panel on the drivers side of the dashboard by the door, it should be plugged in for the DRLs to work, Unplug and see what happends.
  17. #17 Re: New Member Need Assistance Clicking Noise?
    Pull down that panel and use your finger to pinpoint which box is clicking. Once you do that, get a picture of said box and it's location. From there we can tell you exactly which module/function the box does and figure out how to replace it.
  18. #18 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    Quote Originally Posted by JoshsGTP View Post
    Definitely not the DRL. I had them on but I disconnected them. I did not like having them on all the time. The noise came on way after I unplug them.
  19. #19 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    I know where the noise is coming from. I just don't know what that plug is. I'll take a picture of it and post it. Hopefully someone will have an answer.
    The noise is definitely coming from the driver side panel next to the DRL plug.
  20. #20 Re: New Member Need Assistance Clicking Noise?
    GT Level Member donmega's Avatar
    St louis, mo
    if its a click that goes away when you use the combination switch it may be a relay. also before you start disconnecting boxes make sure its not an airbag module......Whatever you do disconnect the battery before hand just in case its an airbag module it doesnt deploy.
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  1. Clicking noise and vibration????????
    By russsellcoltwilliams in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2012, 12:56 PM
  2. Clanking/clicking noise
    By jakewet28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2010, 10:04 PM
  3. Clicking noise at start up
    By jokyfo in forum General Tech Discussion
    Last Post: 08-12-2010, 10:44 AM
  4. clicking noise inside car
    By e6600 in forum General Tech Discussion
    Last Post: 03-22-2010, 03:51 PM
  5. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
