Thread: Boring but necessary - Stud replacement
Results 1 to 8 of 8
flash527 Boring but necessary - Stud... 12-03-2010, 11:07 AM
BillBoost37 Re: Boring but necessary 12-03-2010, 11:31 AM
SJAndrew Re: Boring but necessary 12-03-2010, 11:41 AM
nawarkk Re: Boring but necessary 12-03-2010, 12:21 PM
TheOtherNick Re: Boring but necessary 12-03-2010, 01:38 PM
BillBoost37 Re: Boring but necessary 12-03-2010, 03:18 PM
TheOtherNick Re: Boring but necessary -... 12-03-2010, 08:42 PM
flash527 Re: Boring but necessary -... 12-03-2010, 10:05 PM
  1. #1 Boring but necessary - Stud replacement
    GT Level Member flash527's Avatar
    Indianapolis, IN
    Hey guys, just ordered new studs and lugs for my front passenger tire, as the ones on there are all stripped. Whats the easiest way to get the old studs off? I've never done it before and any tips are appreciated. Thanks!
    04 GTP - FOTB, Intense PCM, 180* Thermo, SLP Headers, 3.4" ZZP Modular Pulley, Moroso Race Wires, 104 Plugs, TEP trans: 3.29's, Thrasher shift kit. Soon to come: 13 inch dual piston brakes, rims and tires, wideband tune by PRJ.
  2. #2 Re: Boring but necessary
    Off is easy. Whack them with a big f'n hammer straight backwards. They'll pop out. The new ones should be able to be slid in. If not, you might find grinding one small edge of the back piece flat does the trick. Then use some spacers and a spare lug nut to yank them back into place.
  3. #3 Re: Boring but necessary
    Denver
    I always eschewed using a hammer for fear of damaging the hub, am I being paranoid?
  4. #4 Re: Boring but necessary
    West Side Michigan
    I've heard putting the new studs in the freezer before install is a good idea, this way they are smaller and slip on easier.
  5. #5 Re: Boring but necessary
    Charles City, IA
    I would have just got a new hub, but yeah do what bill said that is how I always do them.
    SMGPFC Two Nipple General
  6. #6 Re: Boring but necessary
    I like the way you think...but axle nut plus the three hub bolts vs 5 studs. Seems like it's only saving 1 item. Unless the hub has to slide forward to get the studs in.. then it's a no brainer HUB.
  7. #7 Re: Boring but necessary - Stud replacement
    Charles City, IA
    Im not sure if you have to slid the hub forward on these, but broken studs leads me to believe original hub that is going to fail soon anyways so why waste time and money on studs. I could swap out the hub in a lot less time then fighting putting in studs.
  8. #8 Re: Boring but necessary - Stud replacement
    Indianapolis, IN
    studs are 5 bucks. a hub is 75. thats honestly what it came down to. and the studs arent broken they're just stripped. I just had them checked and the hub on that side is fine. the other side is loose, and it'll be replaced next check : )
  1. Boring Kill Story, Problably Shouldn't Read
    By projectxxxmayhem in forum Track Sessions and Kills
    Last Post: 03-05-2010, 11:32 AM
  2. my boring engine bay....
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 08-22-2009, 12:25 PM
  3. a boring hello!
    By racnxtg3 in forum Introductions/Noob Questions
    Last Post: 08-02-2009, 11:41 AM
  4. boring &porting
    By CHAMPS97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2009, 11:44 AM
  5. New car and it is boring!
    By snap on in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 11:13 AM
