Thread: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
Results 1 to 19 of 19
  1. #1 the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Donating Users drewprix86's Avatar
    ATX
    the 04gt's chuggin / studdering at 40-50 when on even the slightest incline. but only for a few moments then is perfect again. i changed the wires/plugs today but i dont think thats it. anything helps guys.
  2. #2 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Nov 2009
    Des Moines, IA
    Any Codes? What gear does this happen in? Does the car downshift when it does this or just light throttle in 4th? Need more info to help you
  3. #3 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    no codes. and 2nd and 3rd i think
  4. #4 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    okay, well i have narrowed it down to the spark plugs i think. i noticed that the middle front boot was not in as far as the rest. i replaced that wire. its not doing it as bad but it is def. still doing it. i used app606 autolie double platnium plugs. man this sux. i think the wires i bought may just be ****. they were $20 at advanced. xact was the brand here is a link
    Advance Auto Parts: Search Results for spark plug wire
    hope this helps
  5. #5 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    $20 wires? Sounds a little cheap.
  6. #6 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    well i was broke and pulled the boot off the wire and that was all i could afford. u think shtty wires could make the car bogg out?
  7. #7 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Florida
    Yeah they could, having a break in the wire coating, or a weak spot, the spark can jump to anything else metal. My 2002 had the same deal, but it was more on/off, depending on engine load. So one night we popped the hood, and revved it some, and sure enough, we saw sparking.
    Replaced the wires with some 10.3mm wires, no problems since.
  8. #8 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    thank you man. ima check that as soon as my wife picks me up. i sure hope ur right. cuz if it is the trany (kow) im fcked
  9. #9 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Florida
    lol, if its the tranny, it feels totally different...kinda hard to explain.
    Either way, it sounds very similar to what my car was doing, so hopefully it'll be a good fix for you too
  10. #10 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Nov 2009
    Des Moines, IA
    Just a tip, you might already know this. The easiest way to spot arcing is to park the car somewhere really dark at night, like an unlit parking lot or something, pop the hood with the car idling and have a look, have someone with you to rev the engine as well, you'll be able see any sparks easily.
  11. #11 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    cool. am i looking at the boots?
  12. #12 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Florida
    You're looking everywhere from the Coil packs, all the way along the plug wires, to the plugs themselves.
  13. #13 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    nope. no sparks. i dont ****ing know. i know its not the trany. its like a limiter almost. it just wont go. and it seems to be wors. i feel like it has 1/2 power. im so pissed. ima just buy new wires and hope for the best
  14. #14 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Florida
    Also, no idea your mods, but if you've got the stock catalytic converter, that could also be it...
  15. #15 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    its new but oem.
  16. #16 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    do you have an aeroforce? or something to check DTCs?
  17. #17 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    problem solved. dont buy $18 xact wires from advanced!!!! threw some $35 bocsh's on there and now im running right again!!!!!!!
  18. #18 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    Florida
    Damn straight... Glad it was an easy fix for you.
  19. #19 Re: the 04gt's chuggin / studdering at 40-50 when on even the slightest incline.
    ATX
    **** me too homie,,....... me too
  1. studdering after starting
    By sgatins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 05:05 PM
  2. car studdering and other wierd symptoms
    By copperpacecar in forum General Tech Discussion
    Last Post: 05-01-2010, 06:28 PM
  3. XP cam, new engine, Rich and studdering when hot, great otherwise
    By tylerbinski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 03:49 PM
  4. Engine chuggin
    By dewski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 07:51 PM
