Thread: Supercharger Speed Question
Results 1 to 9 of 9
  1. #1 Supercharger Speed Question
    SE Level Member BigTom73's Avatar
    Wilkes-Barre, PA
    I was running some numbers and I'm not sure if my math is wrong or one of my assumptions.
    The Eaton M90 "redline" speed is about 14,000 rpm. Using a 3.0 pulley, the supercharger will be above redline before 6000 rpm.
    Is that right?
    That means the supercharger is redlining before the engine is?
    If that is the case, then why run a pulley that small or smaller?
    97 Grand Prix GTP
  2. #2 Re: Supercharger Speed Question
    the m90 really has no max rpm that its supposed to run and it isnt limted. there is just a point where youre making more heat than you need to, which is in the 3.2-3.0 pulley area. eaton pretty much tells us we shouldnt be going below a 3.4 or so.
  3. #3 Re: Supercharger Speed Question
    Pennsylvania
    Quote Originally Posted by BigTom73 View Post
    Is that right?
    My brain's being lazy this morning. Could I trouble you to show your work, please? (Not doubting, just intrigued)
  4. #4 Re: Supercharger Speed Question
    Wilkes-Barre, PA
    Not a problem
    If you want the speed of the supercharger all you have to do is multiply the engine speed by the drive ratio. This ratio is equal to the diameter of the harmonic balancer divided by the diameter of the supercharger pulley.
    You get that by the following:
    In one revolution of the crank the belt moves a distance equal to the circumference of the harmonic balancer. One revolution of the supercharger results from the belt moving a distance equal to the circumference of supercharger pulley. Since circumference is equal to pi times the diameter, the drive ratio can be expressed in terms of the diameter of the harmonic balancer to the diameter of the supercharger drive pulley.
    For an engine speed of 6000 rpm with a 3.0" supercharger drive pulley and a harmonic balancer with a diameter of about 7.16" the supercharger speed would be 14,320 rpm.
    97 Grand Prix GTP
  5. #5 Re: Supercharger Speed Question
    Pennsylvania
    "...the redline of the supercharger is 14000, but that doesnt mean you cant spin it to 16000 at your car's redline. Obviously you want to not overwork the supercharger, but the redline is more a consideration for marine applications where the motor is constantly moving at high rpm. In a car, you spend very little time at the redline even when racing. " Found here
  6. #6 Re: Supercharger Speed Question
    The limit of realisticness on the GenIII stops at a 2.6"...honestly...if you go lower...its just overkill IMO. Anything lower than that is just one of those..."just because I can" things. Also, like the GenV...it stops at the 2.8"...proven time and time again the GenV takes too much power off of the crank to MAKE power when going lower than the 2.8".
  7. #7 Re: Supercharger Speed Question
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Supercharger Speed Question
    Pennsylvania
    Okay, so what are we looking at here?
  9. #9 Re: Supercharger Speed Question
    Hagerstown,Md
    Quote Originally Posted by SlowNA06 View Post
    Lets use the OP 3.0 pulley. Your flowing roughly 650CFM with a 3.0 pulley, 55hp or so is ate by the blower and a temp of 250 degrees. This is where intercooler start to really help
    Now if we can convert CFM to Lbmin we could get a HP number But my math sucks and the equation is huge.where P is absolute pressure and T is temperature in degrees Rankine (Fahrenheit + 460):
    P(psia) x V(cu.ft./min) x 29
    (10.73 x T(deg R))
  1. question supercharger
    By timmysgtp in forum General Tech Discussion
    Last Post: 08-16-2010, 06:35 PM
  2. Speed Daddy headers question
    By 00RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2010, 09:13 AM
  3. new supercharger question
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 09:49 AM
  4. supercharger question
    By nimblett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 09:54 PM
  5. Gen 3 Supercharger Question?????
    By gtpracer0186 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 10:02 PM
