Thread: 01 GP Drivers Window issue. Need Help.
Results 1 to 3 of 3
  1. #1 01 GP Drivers Window issue. Need Help.
    Nov 2010
    NE Indiana
    Hello all. Been reading hear for quite some time but my first post. I have a 01 4dr GP GT and this morning while driving to work I went to put the drivers window down a smidge and then it wouldn't go back up. You can actually push it down or pull it up with by hand. When you push the window control button do can hear it engage and like it is trying to move the window but nothing happens. I took the door panel off to push the window up and to see if it is was on the track etc but its raining and I didn't have much time to spend. Any thoughts on where I should start with trying to fix the issue. Don't have a ton of funds to replace everything until I get it right.
    THanks for any hlp you all can offer.
    Matt
  2. #2 Re: 01 GP Drivers Window issue. Need Help.
    Donating Users
    South Deerfield, MA
    Sounds like you need a new motor/regulator assembly.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: 01 GP Drivers Window issue. Need Help.
    Quakertown, PA
    I just replaced my driver's side, rear regulator and motor. Same exact symptoms. After I pulled out the old regulator and motor, I found out that the one cable that is attached to the sliding part of the regulator had pulled out of the plastic holder. The plastic holder was broken. Can't fix this. So, I bought a used regulator and motor from Ed Morad for $22. Easy to fix. 4 bolts for the regulator, 3 for the motor and 2 for the window. Altogether about 1 hour total. Lubed the regulator with white lithium grease and the felt window tracks with dry silicone spray.
    Everything works great now.
    '02 - 3.8(K) 153,000 miles, New UIM, New LIM alum. gasket, new lifters, new OEM cat. Runs great ! Owned it since new. (bought it 12 years ago with only 22 miles on the clock)
  1. Drivers Side Window Switch Panel
    By hacket in forum Visual/Body Modifications
    Last Post: 09-15-2009, 04:26 PM
  2. Window Regulator + Bracket, are drivers 2 dr and 4dr the same?
    By Quicklynx in forum Visual/Body Modifications
    Last Post: 07-14-2009, 06:21 PM
  3. slow drivers side window
    By Jakegday in forum General Tech Discussion
    Last Post: 12-21-2008, 12:58 PM
