Sounds like you need a new motor/regulator assembly.
I just replaced my driver's side, rear regulator and motor. Same exact symptoms. After I pulled out the old regulator and motor, I found out that the one cable that is attached to the sliding part of the regulator had pulled out of the plastic holder. The plastic holder was broken. Can't fix this. So, I bought a used regulator and motor from Ed Morad for $22. Easy to fix. 4 bolts for the regulator, 3 for the motor and 2 for the window. Altogether about 1 hour total. Lubed the regulator with white lithium grease and the felt window tracks with dry silicone spray.
Everything works great now.
