Thread: Oil Leak
Results 1 to 5 of 5
  1. #1 Oil Leak
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    So I changed my oil today and I noticed my oil pan looks like it is slightly leaking. What should I do? Don't you have to pull the engine to get the oil pan off because of everything in the way? I don't have the equipment to do that myself.
  2. #2 Re: Oil Leak
    Is it dripping? Or kinda just slowly pooling on the indent on the bolts?
    I would just spray it down with some brake cleaner and tighten the bolts that you can reach a smidge.
  3. #3 Re: Oil Leak
    St. Louis
    Once you try and tighten the bolts, if it is still leaking then no, you don't have to pull the motor to change the gasket. You will however need to remove the motor mounts and jack the engine up some to clear everything. You may also have to remove the oil pickup tube inside the pan once you get it loose, depending on how high you jack the engine up. I did it on my 00 GT and it wan't too difficult, just time consuming.
  4. #4 Re: Oil Leak
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I had mine fixed from the dealer, it was still covered under warranty. They had to drop the whole front craddle. I kno urs is an 01. I'd def. Recommend that you use a good gasket maker instead of a gasket. It seems after all these yrs they still didnt get it right. You only wana do this once. Good luck,
  5. #5 Re: Oil Leak
    Nov 2010
    Its more of a pooling on the bolts and the side of the pan has oil on it. But no dripping. So ill try to tighten the bolts I can get too and Ill go from there if it is still leaking ill probably ask more question on how you jacked it up. Thanks
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. got a leak
    By SINister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 06:25 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  4. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  5. Bad oil leak
    By evilpacker in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-29-2009, 09:56 AM
