Hey guys, so recently the weather has turned cold and frosty. I also not so recently put in a ZZP PCM, and shift kit, everything ran great. Then I installed TB spacer and sheild, 180 T-stat, and removed the EGR. And coinsidently it got cold at the same time. Now though I smell a strong gas smell when sitting still, at first I thought it was just running rich because of the cold start up, cause once moving the smell goes away. But then after the car has reached temp, and I stop and idle again I can smell it again through the vents. A quick look under the hood revealed no gas leak or strong odour. And the only puddles in the morning are when I idle it the moisture comming out the exhaust. Was wondering if anyone has an idea where I should look next?
