Thread: 02 GTP strong gas smell when idleing
Results 1 to 14 of 14
  1. #1 Re: 02 GTP strong gas smell when idleing
    Kamloops B.C Canada
    Quote Originally Posted by Colossus View Post
    intake air temps, look into making a fender wall intakes or if you have the $ (although another waist) a thrasher intake box.
    I have plans already for a ram air hood and intake. but its a while off (have a list of projects that never ends). and i see your guys point about the gaskets. I will most likely take it out later when i have some free time, or i will build a 1/6" aluminum block off plate with the cool CNC table the shop just got so no coolent flows into it. and i will test (with are temp gun) to see if it stays colder or hotter than stock.
    back to the original topic of the forum, I went rummageing around and found the leak, the schreader valve on the fuel rail is leaking. so the innards screw out and can be replaced. so i ordered new innards $10 but they will be 7-10days so the cars gunna be sitting as much as possible till then cause its leaking onto the injectors and valve cover, and i had a buddys, buddy, burn his car to the ground because of a fuel leak.
  2. #2 Re: 02 GTP strong gas smell when idleing
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Wigglesworth View Post
    You are completely missing the piont. Outlet temps matter. Not the heat of the throttle body or Blower. Outlet temps can reach well over 300 degrees
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. ? If Hot could have a smell 97 GTP
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-16-2010, 02:11 PM
  2. Bad Smell
    By GMPUNK in forum General Tech Discussion
    Last Post: 07-08-2009, 04:50 PM
  3. 1500 Members strong!!!
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-12-2008, 09:09 PM
  4. Six Months Old and Going Strong
    Last Post: 06-16-2008, 02:39 PM
  5. Idleing with 65# inj
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2008, 08:41 PM
