Thread: Replaced hub. Now have problem.
Results 1 to 13 of 13
  1. #1 Re: Replaced hub. Now have problem.
    Aug 2008
    Louisville
    good call. i'll double check the plate.
    let me run down my senario a little more so you all can better understand what i have going on.
    originaly, i was getting the typical TC and ABS errors on the DIC.
    went to a brake place to have codes read and they said it was the driver side hub.
    i replaced the hub as per the write up's on the forum.
    the fix worked fine for a couple months and then i heard a rubbing; just like a dry bearing and its been getting worse as the months go on.
    now im getting TC, ABS, and steering errors at every start up.
    i havent traced the wires from the hub to the ECU?? to see if theres a bad wire. is there something/somewhere specificaly to look for bad wires?
    i'll have to search the forum to get more clarity on this backing plate issue as i cant picture it in my head. if its right up against the rotor, it cant be that hard to figure out i wouldnt think.
    if anyone has pics/info on the plate and wiring harness, id appreciate it greatly.
  2. #2 Re: Replaced hub. Now have problem.
    Why did you have to do that to me? You didn't mention the months between and I give you a perfect answer. Nice, easy...free.
    Then you went and ruined it all. Crushed my dreams of helping you solve it for free. it's probably another hub gone bad.
  1. Replaced blower motor, still nothing. HELP PLEASE!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-18-2010, 01:04 PM
  2. Replaced hub car still humming
    By Cbierniat24 in forum General Tech Discussion
    Last Post: 04-27-2010, 10:28 PM
  3. Replaced speakers, need opinion on amp???
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2010, 12:10 PM
  4. I replaced the Oxyg sensor now what
    By lfernes in forum General Tech Discussion
    Last Post: 11-30-2009, 08:45 AM
  5. Replaced LIM Car Wont Start
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2009, 04:56 PM
