Thread: Replaced hub. Now have problem.
Results 1 to 13 of 13
  1. #1 Re: Replaced hub. Now have problem.
    Aug 2008
    Louisville
    bump. gonna re-do this bearing this weekend.
    here's the Timkem bearing im replacing...
    Timken/Wheel Bearing/Hub Assembly-Front (513179) | AutoZone.com
    any advice on lubing this thing? where/how?
    thanks guys
  2. #2 Re: Replaced hub. Now have problem.
    Hang on there buddy. You likely don't need a new hub.
    Many times when we are fighting the hub, we bend the backing plate a little. This causes it to rub on the rotor in turns as the rotor flexes a little.
    Check the backing plate before you spend the money if possible.
  3. #3 Re: Replaced hub. Now have problem.
    PS.. our bearings don't get lubed. They are sealed units and ... yeah. No lube.
    I'm pretty (90% or more) sure you have a slightly rubbing backing plate.
  1. Replaced blower motor, still nothing. HELP PLEASE!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-18-2010, 01:04 PM
  2. Replaced hub car still humming
    By Cbierniat24 in forum General Tech Discussion
    Last Post: 04-27-2010, 10:28 PM
  3. Replaced speakers, need opinion on amp???
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2010, 12:10 PM
  4. I replaced the Oxyg sensor now what
    By lfernes in forum General Tech Discussion
    Last Post: 11-30-2009, 08:45 AM
  5. Replaced LIM Car Wont Start
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2009, 04:56 PM
