Thread: Dex-Cool
Results 21 to 40 of 42
  1. #21 Re: Dex-Cool
    Dec 2008
    maine
    Apparently new dex is okay.
    you want a hybrid OAT coolant.
    Prestone LL is probably good.
    Hi
    "New" dex is just like "old" dex..its just called "new."
    For the reasons listed above, I would flush and use a silicated coolant. G-05 and its clones (Mopar "Long Life" and Ford "Gold" ) fit that description, or just go with a real traditional green coolant....that has silicates listed clearly on the bottle.
    Remember: Color means nada. Ingredients is everything.
    1999 Buick Regal LS
    GTP Duals
    12" Brake Upgrade
    GMPP Upgrade Sways / Links
  2. #22 Re: Dex-Cool
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    i went green in mine too , had a issue with a heater hose over spring and summer , was a small leak , lazy didnt want to change it out again (new hose had 2 pinholes in it ) so i just ran water for the spring and summer . finally got off my lazy butt and fixed the hose , but did a cooling system flush cause the water was rusty looking , btw swapped mine over to green 4 years ago when i got it just to be safe .
  3. #23 Re: Dex-Cool
    I would never run straight water. Along with keeping your cooling system from freezing, coolant/antifreeze helps keep water from boiling. You can get the coolant hotter than 212* and still be fine.
  4. #24 Re: Dex-Cool
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    I ran pure water up until a couple weeks ago simply because I was doing a system flush over the summer. My only concern was rust and not having lubrication for the water pump seal. Other than that, I didn't see any steaming like I thought I would. I was actually surprised about that.
  5. #25 Re: Dex-Cool
    streamwood
    i have heard more than once that the dex will create a very thick substance that will build up in the system. i finally got to see it first hand when i took off my intake to do gaskets. there was a thick substance almost greese like in the coolant passages on the heads. I switched to the green since it has never failed me in the past.
  6. #26 Re: Dex-Cool
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Quote Originally Posted by TCO View Post
    ^ TCO I agree: Water does become PUSHY at 212 deg
    ^ SnowDrift I agree: Never ever run just water (Lubricant for the water pump seal).
    One week of 100% pure water = One YEAR of 100% pure grief.
    Personally, I will never, ever run pure water ever again.
    Believe who you will, then do what you must.
    Crazy problems. Drove me nuts for about a year.
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  7. #27 Re: Dex-Cool
    let's toast til we die brand121's Avatar
    South Carolina
    DEX does have a tendency to gum up. I have switched all of my newer model cars to the green stuff, it's been in my 98 Astro for 10+ years and I've had no problems, plus, all of the coolants say that they protect aluminum now... Absolutely wouldn't run straight water though...
    My couch pulls out, but, I don't...
  8. #28 Re: Dex-Cool
    Texas
    Okay sounds like a plan...First chance I get, I'll flush the system and go green. I was just hesitant at first because of the huge sticker on the resivour "ONLY use Dex-Cool Coolant!". I trust you guys however, so green it is
  9. #29 Re: Dex-Cool
    SE Level Member buckslayer's Avatar
    valparaiso,IN
    My 2007 GXP has the dexcool in it and I have noticed "mud" in the over flow tank why is that , it can't be good . I want to flush it and change it to green or yellow . Is this a good idea or not.
  10. #30 Re: Dex-Cool
    VERY good idea.
  11. #31 Re: Dex-Cool
    dex only gunks up when its exposed to air in the system. you people are crazy.
  12. #32 Re: Dex-Cool
    flushing it is a very good idea.
    doesnt matter what you fill with as long as you keep it fresh.
  13. #33 Re: Dex-Cool
    Dec 2008
    maine
    Hi
    If you are going just by mere color, you really have no idea what you are using.
    FWIW, OAT coolant seems better suited to the new all-alu engines. Cast iron seems to react badly to a beach headed dex system.
    1999 Buick Regal LS
    GTP Duals
    12" Brake Upgrade
  14. #34 Re: Dex-Cool
    GTP Level Member SuperSport's Avatar
    Michigan
    Exactly. I cant believe how many people (on this site and other GM sites) that people just claim Decool will just gum up at the drop of a hat, no rhyme or reason.
    Everything happens for a reason people.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  15. #35 Re: Dex-Cool
    things are logical? Since when?
  16. #36 Re: Dex-Cool
    Apr 2009
    stockton ca
    I choose to switch because the other"green stuff" is less tempermental
    its true that if you flush every 2 years and keep the system prperly sealed you shouldnt have issues with any coolant
    BUT 50% of people think filling it with gas is proper car care
  17. #37 Re: Dex-Cool
    QC, Canada
    I've read around GM-oriented forums that switching from Dex-Cool to "Prestone" (green stuff) will eventually cause your water pump to fail since it's not the same thing.
    I found that strange but I can't deny nor believe it. Anybody has a word on this?
    2007 Pontiac Grand Prix GT Supercharged | 105,000 kilos / 65,200 miles
    DEAD (9/28/'13) 2000 Pontiac Grand Prix GT | 161,400 kilos / 100,300 miles
  18. #38 Re: Dex-Cool
    Quote Originally Posted by KingVee View Post
    thats a straight up lie.
  19. #39 Re: Dex-Cool
    Apr 2009
    stockton ca
    Thats bs
  20. #40 Re: Dex-Cool
    Apr 2009
    That's right up there with the myth that once a person uses synthetic oil, they can never switch back to natural oil.
  1. Not cool...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 10-18-2009, 09:42 PM
  2. Is Everyone cool out there!
    By Sameer in forum Introductions/Noob Questions
    Last Post: 10-10-2009, 08:45 AM
  3. cool...new guy
    By virility26 in forum Introductions/Noob Questions
    Last Post: 06-08-2009, 11:44 AM
  4. M90'ed V8 - Very Cool Car!
    By Abrasive in forum Off Topic Discussion
    Last Post: 11-04-2008, 07:18 PM
  5. cool 4 anyone who has one......
    By boosting98 in forum Off Topic Discussion
    Last Post: 10-26-2008, 07:04 PM
