Thread: Right Running Light Issue
Results 1 to 6 of 6
mlasnoski Right Running Light Issue 09-29-2010, 08:29 PM
mlasnoski Re: Right Running Light Issue 09-29-2010, 11:02 PM
GrandPrixSE Re: Right Running Light Issue 09-30-2010, 12:38 AM
mlasnoski Re: Right Running Light Issue 09-30-2010, 12:33 PM
GrandPrixSE Re: Right Running Light Issue 09-30-2010, 06:25 PM
mlasnoski Re: Right Running Light Issue 09-30-2010, 10:21 PM
  1. #1 Right Running Light Issue
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    Hello All,
    I have a 04 GTP CompG with 100,600 on the clock. Just a weird question for you all. Has anyone had problems with their passenger side running light. It's burnt out twice now in a very short period of time. I've noticed it burns out when its raining....
    I did put new headlight and fog/running light assemblies in. I wonder if there may be more space in between some where causing rain to get in and short it? That's the only issue.
    Should I just use electrical tape and tape up all the wires down there? The bummer cover seems to be in place correctly.
    Any Ideas?
    Thanks!
  2. #2 Re: Right Running Light Issue
    Jun 2010
    I should also mention, its just the blinker part of the light. The actual filament that stays on when the car is on, is fine. Is there such thing as a blinker fuse that could be popping?
  3. #3 Re: Right Running Light Issue
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    all blinkers are ran off 1 fuse. So if the others work, then its either the bulb socket or the bulb itself.
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  4. #4 Re: Right Running Light Issue
    Jun 2010
    I figured it out today after the weather dried up a bit. The wire harness that goes to the fog is a little bit loose, thus causing the blinker part of the bulb to not work. I jiggled it a bit and now it works again. =) I'll just order a new wire harness, I doubt its that expensive. It isn't very long.
  5. #5 Re: Right Running Light Issue
    Jun 2010
    Indy
    Glad you found the problem!
  6. #6 Re: Right Running Light Issue
    Jun 2010
    Now lets see if I can just buy the harness. From the parts lists I've been looking at, it doesn't look like its possible. It has to be the wire harness. It tripped again when I was leaving work tonight. Its just the blinker wires on that set of wires. Weird.
  1. temp light issue
    By disblile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2016, 12:55 PM
  2. 0 rpms and tcs light on while car is running?
    By quadracer960 in forum General Tech Discussion
    Last Post: 03-27-2013, 08:45 PM
  3. Daytime running light (DRL) modification help
    By Vinton GP in forum General Tech Discussion
    Last Post: 09-28-2009, 08:09 PM
  4. How to turn off daytime running light on 2008 GP
    By timc in forum General Tech Discussion
    Last Post: 02-06-2009, 01:51 PM
  5. Help Car running rough SES light MAF dead
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 07:25 PM
