Quote Originally Posted by fremmy182 View Post
i think i have the same problem.. mostly when i am trying to merge on the highway and press down on the pedal the rpms try to go up but it just stays in the same spot.. do you think it could be my throttle body also
No your problem is probably ignition related. Your throttle isn't sticking, it's working. Your likely seeing a ton of KR. Try a tune up and see if that helps.
