Thread: Throttle stuck
Results 1 to 13 of 13
  1. #1 Re: Throttle stuck
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    My bikes do this fairly often (as they are motocross bikes), the case with them is usually a gummed-up throttle cable.
    But in this case, I agree with Bio. Pull the boot off and see.
    Bio, what do you suggest to clean it? I would think something similar to WD-40 would do the trick?
  2. #2 Re: Throttle stuck
    Apr 2009
    Maine
    Throttle body cleaner.
  3. #3 Re: Throttle stuck
    Quote Originally Posted by J GTP View Post
    Then there is that...lol
    Kinda forgot
  4. #4 Re: Throttle stuck
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i think i have the same problem.. mostly when i am trying to merge on the highway and press down on the pedal the rpms try to go up but it just stays in the same spot.. do you think it could be my throttle body also
  5. #5 Re: Throttle stuck
    Quote Originally Posted by fremmy182 View Post
    No your problem is probably ignition related. Your throttle isn't sticking, it's working. Your likely seeing a ton of KR. Try a tune up and see if that helps.
  1. o2 is stuck
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:48 PM
  2. This is what im stuck with...
    By TorqueAutoMotiv in forum The Rant Forum
    Last Post: 09-11-2009, 09:39 PM
  3. stuck in a rut
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 12:50 AM
  4. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
