Thread: Throttle stuck
Results 1 to 13 of 13
  1. #1 Throttle stuck
    Iowa
    Hi I have a 1999 GTP and everytime i try to drive it it seems to stay at the throttle level. I push the gas to weather its 2k rpms to 6k rpms. This is making it so I will not drive it but I love the car and was wondering if anyone had anything like this happen? I have asked some mechanically inclined friends and know one seems to have any good ideas.
  2. #2 Re: Throttle stuck
    clean the throttle body to make sure the blade isnt binding up, which it probably is.
    if thats not the case, then replace the throttle cable.
  3. #3 Re: Throttle stuck
    Grand Island, Nebraska
    Sure you arent driving a toyota? sorry someone had to say it.
  4. #4 Re: Throttle stuck
    Minnesota
    Quote Originally Posted by JoRoW99 View Post
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  5. #5 Re: Throttle stuck
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    My bikes do this fairly often (as they are motocross bikes), the case with them is usually a gummed-up throttle cable.
    But in this case, I agree with Bio. Pull the boot off and see.
    Bio, what do you suggest to clean it? I would think something similar to WD-40 would do the trick?
  6. #6 Re: Throttle stuck
    Apr 2009
    Maine
    Throttle body cleaner.
  7. #7 Re: Throttle stuck
    Quote Originally Posted by J GTP View Post
    Then there is that...lol
    Kinda forgot
  8. #8 Re: Throttle stuck
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i think i have the same problem.. mostly when i am trying to merge on the highway and press down on the pedal the rpms try to go up but it just stays in the same spot.. do you think it could be my throttle body also
  9. #9 Re: Throttle stuck
    Arnprior, Ontario
    it could also be you throttle position sensor(TPS) or your idle air control valve(IAC) mine was doing that and i changes those and it works alot better, now mine only sticks open when it warms up but as soon as i start driving at normal speeds it stops sticking, so i am tryint to figure this one out now, it almost seems like the spring on the throttle body isnt strong enough anymore when it heats up
  10. #10 Re: Throttle stuck
    SE Level Member 1fastgtp's Avatar
    Jun 2011
    Lewiston
    try cleaning the throttle body
    2000 Grand Prix GTP: Modifications: SLP catback exhaust-SLP Headers- 180 Termostat- wizaired cold air intake-PRJ 10.4mm wires- autolite 104's- zzp tune- full size intercooler- vs cam- 3.0" pulley ETC. Fastest Grocery Gitter in town
  11. #11 Re: Throttle stuck
    Arnprior, Ontario
    I have taken it off and cleaned the throttle body, and it still seems to stick
  12. #12 Re: Throttle stuck
    Feb 2010
    Virginia
    Quote Originally Posted by MIke79 View Post
    can you be a little more descriptive?
  13. #13 Re: Throttle stuck
    Quote Originally Posted by fremmy182 View Post
    No your problem is probably ignition related. Your throttle isn't sticking, it's working. Your likely seeing a ton of KR. Try a tune up and see if that helps.
  1. o2 is stuck
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:48 PM
  2. This is what im stuck with...
    By TorqueAutoMotiv in forum The Rant Forum
    Last Post: 09-11-2009, 09:39 PM
  3. stuck in a rut
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 12:50 AM
  4. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
