Thread: so first mod today (lil unsure)
Results 1 to 19 of 19
  1. #1 so first mod today (lil unsure)
    SE Level Member krimsonwolf's Avatar
    Jul 2010
    knoxville tn
    so i made my own CAI today i want off of the one suggestion for the fenderwell intake but didnt have time to take off bubmber and grind down support. so i removed that lil plastic flange there and just stuck the front end inside of it. it works well looks nice, ill get some pics up for you guys to judge my work soon, but im haveing an issue with the motor at WOT in high RPMs. i haven't had the u-bend deleted so im thinking this is going to be the issue. went to a shop here and im outside an army base so everything is a lil more expensive but for 50 buck the guy can knock it out for me.
  2. #2 Re: so first mod today (lil unsure)
    the u-bend wont cause any issues at WOT. if its bogging and feeling a loss for power look at the cat first.
    also, youre wasting your time with an FWI. a short ram is more than enough and probably performs better than an FWI with a bunch of bends in it.
  3. #3 Re: so first mod today (lil unsure)
    Jul 2010
    knoxville tn
    It's not really a fenderwell intake it has one bend and goes to the same fender well on the driver side that it would of I just couldn't find a way to use the 4 in pipe he said to use so I went with three in.
    It just seems like the motor bogs down I thought maybe releasing back pressure in the exaust will help or u think that the chip just doesn't know what to do with the extra air coming in
    When I step on the pedal it just seems like the motor stall but the Rome keep tring to build and around 95mph it has issues with the motor
  4. #4 Re: so first mod today (lil unsure)
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    three inch is to small IMO, and sticking the filter into the fender is a waste. I ran a 3 inch when I first slapped my blower on and then went to a 4 inch. Car felt like it could finally breath
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: so first mod today (lil unsure)
    Chip? wth.
  6. #6 Re: so first mod today (lil unsure)
    Pennsylvania
    Get a can of CRC Mass Airflow Sensor cleaner and spray the **** out of the little wires in your MAF. It's old enough to be plenty dirty. If you put an oil-soaked filter on it, some of the oil will get sucked in and coat your sensor. Also, while you're in there, see if the throttle body is all gummed up.
    Other things:
    Fresh fuel filter
    Fresh stock heat range spark plugs
    Fresh spark plug wires
  7. #7 Re: so first mod today (lil unsure)
    Jul 2010
    knoxville tn
    OK so i need to work to get the pics of it on here they are to big ill try changeing it around and see if it helps any and also check the TB for gunk ill let you guys know im still going to go ahead and have the u bend deleted so its done and over with
  8. #8 Re: so first mod today (lil unsure)
    Have the cat deleted at the same time just to rule it out.
  9. #9 Re: so first mod today (lil unsure)
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by 01gpgt01 View Post
    couldnt agree more.... why would you make an intake with piping SMALLER then stock?? (the throttle body opening is 3.75 inches). Its like you took a step backwards
    with that in mind, i gotta ask; did you have this "bogging down" issue before you installed your new intake?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  10. #10 Re: so first mod today (lil unsure)
    Pennsylvania
    Lol, I had to read that three times. Thought you told him to delete the car. You know, just to rule it out.
  11. #11 Re: so first mod today (lil unsure)
    MA
    did you take out the TB screen because i had this issue when I did my cai and once i put the screen back on the car did not bog.
  12. #12 Re: so first mod today (lil unsure)
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    pics pics pics
    2007 Grand Prix GXP
  13. #13 Re: so first mod today (lil unsure)
    Jul 2010
    knoxville tn
    whats a good program to use to get my pics sized right off my iphone to fit on this page
    no i didnt have the problem before before i did the cai and the throttle body screen is still in and the MAF sensor was all cleaned out. im going to take it somewhere and have some one read the stuff off the computer is not triping any codes but for that mater it hasnt in a while maybe the light dosent work anymore.
  14. #14 Re: so first mod today (lil unsure)
  15. #15 Re: so first mod today (lil unsure)
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    if u messed with the intake and immediatly after got problems why the hell did u immediatly start assuming the u bend or car? start by finding out what u screwed up and leave the exhaust alone...for now
  16. #16 Re: so first mod today (lil unsure)
    Jul 2010
    41 R QR 51938 02935
    Quote Originally Posted by krimsonwolf View Post
    photobucket works pretty well
    2007 Grand Prix GXP
  17. #17 Re: so first mod today (lil unsure)
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by copperpacecar View Post
    my thoughts EXACTLY. if you did indeed start having this problem right after you put on your intake, it is most likely that restrictive ass 3 inch piping your using.
    why in the world would you make an intake with piping smaller then stock??
  18. #18 Re: so first mod today (lil unsure)
    SE Level Member 4boostin's Avatar
    Feb 2010
    Utah
    IMO your problem was probably there before the CAI, or you messed something up. An open cone 3 inch would probably flow as well as stock. When I put a 4 inch CAI on my car, there was an immediate improvement according to the butt-dyno, front wheels spinning easily....and all the way to redline. It made a huge difference with the stock exhaust in place, u-bend included.
    98GS - 3" DP & Cat back, 9" K&N CIA in FW, Plog, 3.5", 180* Canned tune. 14.65 at 96.9mph, w/2.37 60ft. on G-Timer @ 4500 elev. @ 51*.
    87 Limited Turbo Regal- 12.04 @ 115 -Purchased New. Sold after 23 years and 115,000 miles
  19. #19 Re: so first mod today (lil unsure)
    Feb 2010
    somewhere cold
    i agree...he either didnt connect something right, forgot to plug a sensor back in...caused a vac leak or bumped something and broke stuff...whenever u are moding and immediatly have a problem there after then u should always assume the last think u touched before running around like a chicken with its head cut off
  1. new here and unsure what to do
    By kittie1342 in forum Introductions/Noob Questions
    Last Post: 05-23-2009, 03:12 AM
  2. Just got my SE air dam today
    By Shake_Zula in forum Visual/Body Modifications
    Last Post: 02-28-2009, 10:23 AM
  3. SO Today I did.......
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 11-09-2008, 11:26 PM
  4. It Came Today!!!!
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-15-2008, 04:01 PM
  5. look what come today?
    By nemesis in forum Tires & Wheels
    Last Post: 07-16-2008, 01:01 PM
