Thread: Aeroforce??
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Aeroforce??
    Willoughby, Ohio
    i just ordered the harness, no biggie ill have it workin fine this week
  2. #22 Re: Aeroforce??
    Akron Ohio
    If you need any help just pm me.
  3. #23 Re: Aeroforce??
    Willoughby, Ohio
    thanks man
  4. #24 Re: Aeroforce??
    Willoughby, Ohio
    to the OP, i got that 3 wire connector and removed the jumper and put the red wire to the switched 12V that my other guages are on and now it works great.
  5. #25 Re: Aeroforce??
    Minnesota
    Nice It was a huge relief for me when it started working, I thought I screwed up a 250 gauge before i even seen it work lol
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  6. #26 Re: Aeroforce??
    Slower, Lower Delaware
    Quote Originally Posted by quadracer960 View Post
    If you have an android phone, or iphone, sell the aeroforce, n buy the torque app for $2 or whatever the amount is, and buy a $35 obd2 port bluetooth adapter and there is your $37 scan gauge.
    I can't get Torque to show data for KR. Any hints?
  7. #27 Re: Aeroforce?? Help!!!!!
    SE Level Member 00GTPDAYTONA500's Avatar
    Mar 2012
    Massachusetts
    My aeroforce is doing the same thing. It worked fine a couple weeks ago when I tested it in the cigarette lighter. I get my pod I wire it up and it turns on, shows to parameters with no readings then powers off. I can go in the menu and it will stay on, as Soon as I hit scan, it shuts off. I hit either of the two buttons, it's just red.. Help!!
  8. #28 Re: Aeroforce??
    Mar 2012
    Massachusetts
    Bump. HELP!!
  9. #29 Re: Aeroforce??
    Florida
    IIRC i connected the middle wire to key on power coming out of my sterio. I have a 96 monte. never had a prob
  10. #30 Re: Aeroforce??
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    Just keep it wired into your radio fuse. That works the best from what I've found.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  11. #31 Re: Aeroforce??
    Mar 2012
    Massachusetts
    I have it tapped into the sunroof which is 20amp also. Power is not a problem like I said I can have it in the menu screen forever.. As Aston as I hit scan it shuts off. I tore it apart ounce again and noticed a wire is only holding on bye the casing. It's the black wire on bottom plug, with 8 ports. Which is the one that goes tithe obd2 port I believe. I don't know how to upload a pic from my iPhone on here. Or I would show you guys. Ima try and sauter it.
  12. #32 Re: Aeroforce??
    Mar 2012
    Massachusetts
    Any way I can post the pick of the wire????
  1. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
  2. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
