Thread: Window goes up slowly? Help
Results 1 to 10 of 10
  1. #1 Window goes up slowly? Help
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Ok so during the winter my windows seem to struggle going back up and sometimes even get stuck :/ they are slow even in summer any suggestions on how to cure this problem and restore lost window power thx for reading.
  2. #2 Re: Window goes up slowly? Help
    motors and regulators can be replaced, but the easiest solution is to take apart the window switches and clean them. that might help out a lot.
  3. #3 Re: Window goes up slowly? Help
    Jul 2010
    Broadview Hts Ohio
    clean them with what?
  4. #4 Re: Window goes up slowly? Help
    Wichita
    Or your battery is going bad...
  5. #5 Re: Window goes up slowly? Help
    if thats when the car is on then the motor/regulator prolly needs to be replaced.
  6. #6 Re: Window goes up slowly? Help
    Jul 2010
    Broadview Hts Ohio
    Where is this regulator located? Where can I get one? and can I do it myself? Price? BTW my battery is brand new thx for the input tho
  7. #7 Re: Window goes up slowly? Help
    try the switch thing first and if they're clean then go to your parts store and price one out then try rockauto.com
    Its attached to the motor and assists in moving the window.
  8. #8 Re: Window goes up slowly? Help
    Jul 2010
    Broadview Hts Ohio
    Ok will do thx again. I will let u kno how it goes
  9. #9 Re: Window goes up slowly? Help
    Jul 2010
    Ames
    Next time when you roll down the window, look at the rubber seals leaning against the window. Due to wear, the leather-like inner surface of the rubber may disappear,and the increased friction may turn down the rubbers, causing even bigger frictions.
  10. #10 Re: Window goes up slowly? Help
    GTP Level Member SuperSport's Avatar
    Michigan
    My drivers side was slow last year. I just put the window down, dielectric greased where the vertical part of the window travels and now it goes up and down like normal.
    Just something to try before dropping cash on a motor/regulator...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. My window goes up but not down
    By wesjim in forum Introductions/Noob Questions
    Last Post: 06-11-2010, 04:01 PM
  2. Window help
    By ptnothere in forum General Tech Discussion
    Last Post: 06-09-2010, 12:21 AM
  3. window help??
    By Kizorm in forum General Tech Discussion
    Last Post: 02-27-2010, 11:02 PM
  4. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  5. It's slowly coming together... (lots of pics 56K)
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2008, 04:42 PM
