well i seem to be having a problem with my driver side window, when i hit the button the window goes down but its very weak and when i push the button to make it go up it cant even make it all the way i have to use my hands to pull/push it all the way up.
i was cruising around some sites and came across window motor stuff.
the first thing i found was a power window regulator
New Power Window Regulator<br>LH
the second part i came across was a new window motor but its only for four doors i own a 2 door gt coupe so i figured that cant be right. but as i look at the window regulator it comes with a motor but wheres the regulator?
assuming my problem is with my window motor.
thanks for your help
